Bienvenue sur depanetout, forum d’entraide au dépannage électronique › Forums › Schématèque › Les Modes Services › Mode Service plusieurs Marques › Mode Service plusieurs Marques › Répondre à : Mode Service plusieurs Marques
Service menu ,service mode en tv lcd ,crt plasma et monitor
ACER
code:6163
LCDs :
* SERVICE MENU 1:
Press and hold the {CH+} & {CH -} buttons on
the TV for few seconds.
* SERVICE MENU 2:
Press and hold the {VOL-} & {CH +} buttons on
* AUTO ALIGNMENT:
Press and hold the {VOL+} & {CH -} buttons on
* FACTORY RESET:
Press and hold the {VOL-} & {MENU} buttons on
* Use the {UP} {DOWN} {LEFT} {RIGHT} buttons on the
remote to move through menus and change settings.
* To exit, press the {MENU} button or turn the power off.
#2
* Turn the Monitor on.
* Press and hold the {DOWN} button and
then turn the power off.
* Now press and hold the {UP} button and
then turn the power on.
* The Service Menu will be displayed.
* To exit, turn the power off.
#3
* Press and hold the {LEFT} button and
* Now press and hold the {RIGHT} button and
AKAI
TVs :
* Turn the TV off.
* Press and hold the {VOL+} & {VOL -} buttons
on the TV and then turn the power on.
* Use the {MUTE} and {0-9} numbered buttons to access modes.
* Use the {VOL+} {VOL -} buttons to change settings.
#2
* Turn the TV on.
* Press the {F WHITE} {AUTO} {V CHIP} buttons on the remote.
#3 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
* Turn on the display and select the input that you want to adjust.
* Turn the display off.
* In quick sequence on the remote press:
{MUTE} , {1} , {8} , {2} , {POWER} buttons.
* The Display will turn on with the service menu displayed.
ADJUSTMENT – TEST PATTERN – SET OPTION BYTE – FACTORY RESET
* Select the function and use the {VOL+} to enter the next screen.
* Save settings and exit by pushing {MUTE} twice then {POWER}.
#4
* Turn the TV on.
* Press the {MUTE} {OK} {TV} buttons on the remote.
* Use the {UP} {DOWN} buttons to select options.
* Use the {RIGHT} {LEFT} buttons to change settings.
* Press the {OK} button to save settings.
* To exit, press the {TV} button.
#5
* Turn the TV on.
* Press and hold the {VOL -} button on the TV.
* Press the {MENU} button on the remote,
release the {VOL -} button on the TV and
then press the {TV} button on the remote.
* Now to access the Service Menu, press the {i} button.
AOC
LCDs :
* Press the {POWER} and {AUTO} buttons at the same time.
* « Factory1 » & « Factory2 » Menus will be displayed in the OSD.
to move through options and change settings.
* To exit, press the {MENU} button.
#2
* While the LCD is on, unplug the power cable.
* Then press and hold the {MENU} button while
plugging in the power cable.
* The Factory Mode will be displayed.
* Press the option to save settings.
Bang & Olufsen
TVs :
* Using the remote control:
Press the {MENU} button.
Then press the {0} {0} {GO} buttons.
Daewoo
TVs :
* Press the {UP} {MUTE} {DISPLAY} {MUTE}
buttons on the remote control.
* Use {CH+} {CH -} buttons to select items.
* Use {VOL+} {VOL -} buttons to change values.
#2
* Press the {VOL -} {MUTE} {DISPLAY} {MUTE}
#3
* Press the {1} {MUTE} {DISPLAY} {MUTE}
#4
* Press the {1} {MUTE} {RECALL} {MUTE}
#5
* Turn the TV off.
* Then press the following buttons using the remote:
{DISPLAY} {MENU} {3} {8} {POWER}
* Use {CH+} {CH -} buttons to select menus.
* Use {VOL+} button to access menus.
* Use {CH+} {CH -} buttons to select sub-menus.
* To exit and save, turn the power off.
#6
* Select Channel 91.
* Turn « Sharpness » all the way down.
* Exit all menus.
* Press the {RED} {GREEN} {MENU} buttons on the remote.
* Use {PROG+} {PROG -} buttons to select items.
DELL
LCDs :
* Turn the Display Off.
* Press and hold the {MENU} & {+} buttons.
* While holding both buttons, turn the Display On.
* Once the Display is on, release all buttons.
* Now press the {-} button.
* Press the {MENU} button to exit.
#2
* Press the {MENU} button and select « Factory Reset ».
* Then go to the option « Factory ».
PLASMAS :
* Press the {INPUT} {6} {1} {9} buttons on the remote.
* Input Select: Show Inputs needs to be set to « ALL » .
If it is set to « ACTIVE », It’ll NOT work.
<<< WARNING – WARNING – WARNING – WARNING – WARNING >>>
Do NOT Hit the OK Button while the « ADC Calibration » option is selected
on the service menu. Apparently, this will recalibrate the Dell W5001C
according to whatever is being fed via the HDMI input. In the factory, a
proprietary image (provided by Pixelworks) is used. If you do it at home,
you may as well kiss the set goodbye. It cannot be undone, and you will
likely have to return the set.
Fujitsu
PLASMAS :
* Fujitsu has a Service Menu with limited function.
* Press and hold the {ENTER} button on the remote
until the Service Menu is displayed:
Monitor Mode A – Monitor Mode B – Extend Adjust
* Using the remote keys, select a Mode and press {ENTER} to access it.
* Monitor Mode A :
Fan Settings
Temperature Reading
Hours Meter
To determine total hours, add RGB and video for the total hours on the plasma
(each number represents hours on that selected input).
Disregard total hours. That’s the number of hours the Plasma is plugged in.
* Monitor Mode B :
Shows error codes, if any.
* Extend Adjust :
Fan Mode
AGC
V Screen Orbiter
RS232 Baud Rate
Default (CAUTION: pressing default will reset the hours counter to zero).
* Press menu to toggle from one menu to another.
Funai
Emerson / Symphonic /ilo
TVs : lcd (grandin)
* Enter Menu or Picture Menu.
* Then press the {9} {3} {0} {1} buttons.
#2
* Enter the Main Menu.
or
Enter the Main Menu and access the Install Menu.
* Then press the {4} {7} {2} {5} buttons.
* Use the {UP} {DOWN} buttons to select items.
* Use the {LEFT} {RIGHT} buttons to change settings.
* To exit, press the {MENU} or {EXIT} buttons.
Vestel
#3
* Turn the power on using the {POWER} button on the TV.
* Press the {POWER} {2} {7} {1} {MUTE} buttons on the remote.
* To exit, press the {POWER} button on the remote.
#4
Daewoo
#5
Daewoo
#6
* Turn volume all the way down to ‘0’
* Then press and hold the {VOL -} button on the TV and
the {9} button on the remote control for few seconds.
* Use the {CH+} {CH-} buttons to select items.
* Use the {VOL+} {VOL-} buttons to change values.
Orion
#7
the {0} button on the remote control for few seconds.
Grundig
TVs :
* With the TV in standby:
* Press and hold the {i} button on the remote
while pressing the {POWER} button on the TV.
* The TV will turn on with the Service Menu displayed.
* Use the {UP}{DOWN} buttons to select menus/options.
* Use the {LEFT}{RIGHT} buttons to change settings.
#2
* Press the {i} button.
* Then press ‘OK’ – ‘SERVICE’ – ‘OK’.
* Enter Service Code ‘8500’.
#3
* Press and hold the {i} button.
* Then enter service code ‘8500’.
* To exit, press the {TXT} button.
#4
* Press and hold the {P/C} button on the remote
#5
* Press the {DISPLAY} {MUTE} {SLEEP} {FUZZY}
* The Service Menu will be displayed:
o Factory 1
o Factory 2
o Factory 3
* Use {VOL+} {VOL -} buttons to access menus.
* Use {CH+} {CH -} buttons to change values.
#6
* Turn the TV off.
* Press and hold the {MENU} button on the TV
* Wait until the power light turns on then
* Use the {P+} {P-} buttons to select options.
* Use the {VOL+} {VOL-} buttons to change settings.
Hitachi
PLASMAS :
* Turn the TV off..
* Press and hold the {POWER} and {INPUT} buttons at the
same time on the A/V Media Box for at least 5 seconds.
* Release the {POWER} button first and then immediately
release the {INPUT} button.
* Use the {MENU} button to move through menus.
#2
* Put the TV in standby.
* Press and hold the {POWER} {INPUT} {DOWN} buttons
at the same time on the TV for at least 5 seconds.
MISC TVs :
* Turn the TV on.
* Press {MENU} {MENU} {8} {SELECT} buttons on the remote.
* Press the {EXIT} button to exit the Service Menu.
#2
* Turn the TV off.
* Press and hold the {POWER} and {INPUT} buttons on the TV.
* Hold both buttons until the TV powers on
* To exit, press the {EXIT} button or turn the power off..
#3
* PICTURE ADJUSTMENT MODE :
Press and hold {POWER} and {INPUT} buttons
on the TV for more than 5 seconds.
* AUDIO ADJUSTMENT MODE :
on the TV for 3-5 seconds.
* To exit, press the {POWER} button.
#4
* Press the {I} {M} {P} buttons.
* Use the {UP}{DOWN} buttons to select options.
* Press the {M} button to save settings.
#5
* Press the {SETUP} button and select « Cable Mode ».
* Select « Timer » menu and set sleep timer to 30 min.
* Press {MENU} or {OK} buttons twice to exit menus.
* Tune to channel 124.
* Turn the volume all the down to ‘0’.
* Then press and hold {VOL -} button ON THE TV.
* « CHK » appears in on top-left corner.
* While the « CHK » is displayed, press the {MENU} & {VOL+} buttons
ON THE TV simultaneously to toggle between Modes:
Red « CHK » for Serviceman — Yellow « CHK » for Aging
* Press the {POWER} button on the remote to move through modes.
* Use the {CH+} {CH -} on the remote to select options.
* Use the {VOL+} {VOL -} on the remote to change settings.
* To exit, press the {MENU} and {POWER} buttons on the TV.
RPTVs :
* Press and hold the {MENU} button on the TV.
* Then press the {MENU} {8} {SELECT} buttons on the remote.
* To exit, press the {MENU} button on the TV or
the {EXIT} button on the remote control.
DCAM Mode:
* Hold down the {TV} button.
* Press the {MENU} button.
* Press the {INFO} button.
* Release the {TV} button.
Remote Control Key Functions When In DCAM Mode:
{INPUT} …………. Blue (13×9 adjust)
{ASPECT} ………… ROM Write
{DAY/NIGHT} ……… ROM Read
{MENU} ………….. Remove Color
{EXIT} ………….. Cross Hatch/Video Mode
{INFO} ………….. Green
{GUIDE} …………. Calculation
{2} …………….. Cursor UP
{5} …………….. Cursor DOWN
{6} …………….. Cursor RIGHT
{4} …………….. Cursor LEFT
{0} …………….. RED (7×5 Adjust)
{STOP} ………….. Initialize
{PLAY} ………….. Raster Position
{FAST FORWARD} …… Phase
To Exit The DCAM Mode:
* Press and hold the {TV} button.
* Press the {0} button.
* Press the {1} button.
#2
* Turn the TV off and wait at least 2 minutes.
* Press and hold the {INPUT} and {POWER} buttons
* on the TV for about 2 seconds.
* Use the {UP} {DOWN} buttons to move through options.
* Press the {RIGHT} button for 2 seconds to access options.
* Press the {EXIT} button to exit the Adjustment Mode.
* Press the {EXIT} button again to exit the Service Menu.
Horizon
TVs :
* Enter the ‘Main Menu’.
Vestel
#2
* Enter the ‘Main Menu’ and access the ‘Install Menu’ .
HP
LCDs :
* Then while pressing the {INPUT} & {VOL -} buttons on the remote,
plug the power cable back into the outlet.
* When it powers up you will see a little « k » appear in brackets.
* Then on the TV, press and hold {VOL -} & {CH -} down and release.
* Use {CH+} {CH -} buttons to navigate
* Use {VOL+} {VOL -} buttons to adjust the value.
* Turn the set off to exit the Service Menu.
Sharp
PLASMAS :
PL-4260N / PL-5060N
* Turn the TV on.
* Press the {MENU} button and select « User OSD Menu ».
* Select « Audio », « Settings » and then « Balance ».
* Press the {9} {1} {8} {OK} buttons on the remote.
Remote – Control Keys:
{MENU} ……………. Enter/Exit the Service Menu
{UP} {DOWN} arrows …. Select Items
{RIGHT} arrow ……… Enter Lower-Level Menus
{RIGHT} {LEFT} arrows . Change Adjustment Values
{BACK} ……………. Return to Upper-Level Menu
TV – Control Keys:
{CH+} {CH-} ……….. Select Items
{VOL+} ……………. Enter Lower-Level Menu
{VOL+} {VOL-} ……… Change Adjustment Values
* To exit, press {9} {1} {8} {9} buttons on the remote.
NOTE: If the “M” character appears on the screen,
press the {MENU} button first.
PE-4200N / PL-4200N / PL-5000N
* Hold down {VOL -} button ON THE PLASMA TV.
* While still holding down the {VOL -} button,
press {RECALL} on the remote 3 times.
* Use the {1} {2} button to navigate main menu items.
* Use the {3} {4} buttons to navigate sub-menu items.
Hyundai
TVs :
* Press the {MUTE} {MENU} {OK} {SLEEP} buttons on the remote.
#2
* Press the {MENU} {4} {7} {2} {5}
* There are 4 Menus available:
Display – Calibration – Deinterlacer – Factory Settings
* Use the {LEFT} {RIGHT} buttons to select a Menu.
* Use the {UP} {DOWN} buttons to select Menu options and
then the {LEFT} {RIGHT} or {OK} buttons to change values.
Vestel
#3
* Press the {MENU} {SAP} {SLEEP} {MAGIC}
#4
* Press the {CAPS} {REVEAL} buttons on the remote.
* Use the {REVEAL} button to move through menus.
* Use the {P +} {P -} buttons to select items.
* Press the {OK} button to save and exit.
Iiyama
MONITORS :
* Turn the Display off.
* Press the {POWER} button twice while
holding down the {MENU} button.
* Then press the {POWER} button again
while holding down the {-} button.
* Press the {MENU} button to enter the Service Mode.
JVC
PLASMAS / LCDs / CRTs / RPTVs :
* Press the {MENU} button and go to the User Menu screen, make sure
that the indicator (arrow) is pointed and highlights the « Picture Control ».
* The buttons on top of the remote are set to TV & VCR respectively.
* Set sleep timer to « 0 » minutes and while it is displayed, simultaneously
press the {VIDEO STATUS} & {DISPLAY} buttons.
* Use the number keys {1-9} to select a category.
* Use the {CH+} {CH-} buttons to select options.
* Use the {MUTING} button to save settings.
* Press the {BACK} button to exit the Service Menu.
#2
* Turn the TV on.
* Press the {INFO} & {MUTE} buttons at the same time.
* Use the {VOL+} {VOL-} buttons to enter the category.
NOTE: Some models don’t have category selection.
* Use the {CH+} {CH-) buttons to select options.
* To exit, press the {INFORMATION} button.
#3
* Turn the TV on.
* Press {DISPLAY} & {PIC MODE} buttons at the same time.
* Use the {UP} {DOWN} buttons to enter the category.
* Use the {LEFT} {RIGHT} buttons to select options.
* Use the {UP} {DOWN} buttons to change settings.
* To exit, press the {DISPLAY} button twice.
#4
* Select « Clock Set ».
* Set clock to 3:21 AM and press « Start Clock ».
* While a « Thank You » message is displayed on screen,
press the {MUTE} and {MENU} buttons.
* The Service Menu will come up.
* Use {UP} {DOWN} to select options.
* Use {LEFT} {RIGHT} to change settings.
#5
* Press the {DISPLAY} and {PIC MODE} buttons
at the same time on the remote control.
* Use the {MENU UP} {MENU DOWN} buttons to select options.
* Use the {MENU +} {MENU -} buttons to change settings.
* Press the {DISPLAY} button to exit menus.
* Press the {DISPLAY} button again to exit the Service Menu.
LG
TVs :
* Service Menu #1
Press and hold the {MENU} button on the remote and
the {MENU} button on the TV at the same time,
until the first Service Menu is displayed.
* Service Menu #2
Repeat the above sequence:
until the second Service Menu is displayed.
#2
* Press and hold the {MENU} button on the remote
and the {MENU} button on the TV at the same time
* If a password screen comes up:
again, until the Service Menu is displayed.
#3
* Press and hold the {MENU} button ON THE REMOTE
until a 4-digit password screen is displayed.
* Then try any of the following codes to
access the Service Menu:
{0} {0} {0} {0}
{7} {7} {7} {7}
{8} {7} {4} {1}
#4
* Press and hold the {MENU} button ON THE REMOTE.
(The menu on the screen will disappear)
* Now Press and hold the {MENU} button ON THE PANEL.
* Keep both buttons pressed until the Service Menu
is displayed, then release the 2 buttons.
* Using the remote control buttons:
{MENU} = Toggles between two menu pages.
{UP} {DOWN} = Selects the item for adjustment.
{LEFT} {RIGHT} = Varies the value
{POWER} = Exit service mode and saves adjustments made.
#5
* Turn the TV on.
* Hold down the {MENU} button on remote until the on-screen menu
disappears or « Welcome Message » appears then release the {MENU}
button and within two (2) seconds press the following five buttons:
{9} {8} {7} {6} {ENTER}
or
{9} {8} {7} {6} {DISPLAY}
Loewe
TVs :
* Press the {MENU} button on TV’s front panel.
* Select the « Service » menu option.
* Press the {MENU} button on the remote.
* To exit, turn the set Off.
<<<< WARNING – WARNING – WARNING – WARNING – WARNING >>>>
Adjust option bits that are highlighted only. The other option bits
are for Authorized Technicians. If incorrectly adjusted, some option
bits can cause unrecoverable system failures.
#2
* Press the {FUNCTION} button on TV’s front panel.
* Press and hold the {CH -} button on the remote
{CH+} {CH -} buttons move through menus
{OK} button makes selections
{VOL+} {VOL -} buttons change menu items
{OK} button saves a particular setting
#3
* Press the {MENU} button 5 times on TV’s front panel.
A « Service » message will appear on screen.
* Then press the {MENU} button on the remote.
Marantz
LCDs :
Matsui
TVs :
#2
* Turn the TV off.
#3
* To exit, press the {8} button.
#4
or
* Press the {MENU} button and access the ‘Install’ Menu.
Mitsubishi
TVs :
* Using the remote control press:
{MENU} {0} {3} {5} {3} buttons.
{MENU} {0} {3} {5} {7} buttons.
* Then use {VIDEO} or {AUDIO} buttons
to enter two different groups of adjustments.
* {VIDEO} and {AUDIO} steps along through
the adjustments, and {+} {-} does the adjusting.
* Press the {ENTER} button to save the change.
* Press the {MENU} button twice to exit service menu.
#2
{MENU} {1} {2} {5} {7} buttons.
{MENU} {1} {2} {5} {9} buttons.
{MENU} {1} {3} {7} {0} buttons.
#3
{MENU} {2} {3} {5} {6} buttons.
{MENU} {2} {3} {5} {7} buttons.
{MENU} {2} {3} {5} {8} buttons.
{MENU} {2} {3} {5} {9} buttons.
#4
{MENU} {8} {2} {5} {7} buttons.
NEC
TVs :
* Press {ON} {ON} {EXIT} {DISPLAY} buttons on the remote.
* To exit, repeat access code or turn off the display.
#2
* Press {OFF TIMER} {EXIT} {MENU} {OFF TIMER} on the remote.
or
Press {OFF TIMER} {OK} {MENU} {OFF TIMER} on the remote.
* Use the {PROCEED} or {MENU} buttons to move through menus.
* To exit, turn off the display.
#3
* Press {OFF TIMER} {EXIT} {MUTE} {OFF TIMER} on the remote.
or
Press {OFF TIMER} {OK} {MUTE} {OFF TIMER} on the remote.
Monitors :
* Select ‘Display Mode’.
* Press the {PROCEED} button.
* Then press and hold the {VOL+} & {VOL -} buttons.
* A Warning message will be displayed.
* Press the {PROCEED} button again to enter the Service Menu.
Nokia
TVs :
* Turn the TV off (Standby).
* Press the {3} {7} {2} {POWER} buttons on the remote.
#2
* Turn the TV on.
* Use the {UP} {DOWN} {RIGHT} {LEFT} buttons on
the remote to move through menus and change values.
* Press the {OK} button to save new settings.
* To exit, press the {TV} button or turn the power off.
#3
* Press the {-/–} {MENU} {TV} buttons on the remote.
* Use the {PR+} {PR-} buttons to select items.
* Use the {VOL+} {VOL -} buttons to change values.
* Use the {MENU} button to store new values.
#4
* Press the {I} {M} {PROG} buttons on the remote.
* Use the {UP} {DOWN} buttons to move through menus.
* Use the {LEFT} {RIGHT} buttons to change values.
* Use the {M} button to save settings.
#5
* Press the {MENU} {TV} {I} buttons on the remote.
* Use the number & cursor keys on the remote
* Use the {OK} button to store new values.
PANASONIC
PLASMAS:
# Hold down the {VOL -} button ON THE PLASMA TV.
# Press the {RECALL} button 3 times on the remote.
# The Service Menu will be displayed.
# Use the {1} {2} buttons to navigate main menu options.
# Use the {3} {4} buttons to navigate sub-menu options.
# Use the {VOL+} {VOL -} buttons to change settings.
# To exit and save, turn the power off.
#2
* Set « Antenna A » to « Cable ».
* Press {OK} twice to exit menus.
* Press and hold {VOL -} button ON THE PLASMA TV.
« CHK » appears in on top-left corner followed by 5 letter/numbers
(which are the cumulative hours in hex numbers)
* While the « CHK » is displayed, press the {OK} and {VOL+} buttons
— Red « CHK » for Serviceman — Yellow « CHK » for Aging —
* Press the {POWER} button on the remote to select one of the six
Serviceman Adjustments Modes.
A. MTS ADJUSTMENT
B. CLOCK ADJUSTMENT
C. VIDEO ADJUSTMENT
D. HDEF ADJUSTMENT
E. VDEF ADJUSTMENT
F. DAF ADJUSTMENT
G. OTHER ADJUSTMENT
* Press {CH+} {CH -} on the remote to select the settings
on each of Service Adjustment Modes.
Write down the original values before modifying anything.
It’s easy to erroneously adjust the wrong item.
* Press {VOL+} {VOL -} on the remote to change values.
* Press the {POWER} button on the TV to exit the service menu.
#3
# Using the remote control:
# Press the {MENU} button.
# Press « Setup » menu.
# On « Mode » menu, select « Cable »
# Select « Timer » menu and set sleep timer to 30 min.
# Press {ACTION} twice to exit menus.
# Tune to channel 124.
# Press and hold {VOL -} button ON THE PLASMA TV.
# While the « CHK » is displayed, press the {ACTION} and {VOL+} buttons
# Press the {POWER} button on the remote to select one of the six
A. MTS ADJUSTMENT
B. CLOCK ADJUSTMENT
C. VIDEO ADJUSTMENT
D. HDEF ADJUSTMENT
E. VDEF ADJUSTMENT
F. DAF ADJUSTMENT
G. OTHER ADJUSTMENT
# Press {CH+} {CH -} on the remote to select the settings
# Press {VOL+} {VOL -} on the remote to change values.
# Press the {POWER} button on the TV to exit the service menu.
Philips
TVs :
* Press {0} {6} {2} {5} {9} {7} {INFO+} buttons on the remote.
or
* Press {0} {6} {2} {5} {9} {7} {STATUS} buttons on the remote.
or
* Press {0} {6} {2} {5} {9} {7} {MENU} buttons on the remote.
* Turn the TV off to exit the Service Menu.
#2
* Press {0} {6} {2} {5} {9} {6} {INFO+} buttons on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {STATUS} buttons on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {MENU} buttons on the remote.
#3
* Press {0} {6} {1} {5} {9} {6} {MENU} buttons on the remote.
or
* Press {0} {6} {1} {5} {9} {7} {MENU} buttons on the remote.
* Turn the TV Off to exit the Service Menu.
#4
* Press {1} {6} {2} {5} {9} {6} {MENU} buttons on the remote.
or
* Press {1} {6} {2} {5} {9} {6} {STATUS} buttons on the remote.
#5
* With the TV off:
* Press the 0 key twice on the remote to exit and save settings
#6
* Press the {MENU} button again on the remote or TV
Pioneer
PLASMAS :
PDP-4214
* Press the {INPUT} button on the remote.
* The input list will come up.
* Then press the {0} {9} {1} {7} buttons on the remote.
* To exit, press the {EXIT} button on the remote.
You can also press the back button when you are
in each category to get back to the main menu.
4th / 5th / 6th / 7th GENERATION MODELS
* Make sure the Plasma and the Media Box are in standby.
* Press {DISPLAY} button (just press, do not hold) and wait 3 seconds.
* Press {LEFT} {UP} {LEFT} {RIGHT} {POWER} buttons.
* The Plasma will turn on with the « Information Menu » displayed.
* Press {MUTE} button to move through Modes:
o INFORMATION
o FUNCTION CHECK
o COMMON ADJ
o OPTION
o INITIALIZE
* Press the {DOWN} button to select menus.
3rd GENERATION MODELS
* Power Down at the panel.
* Hold down {INPUT} & {VOL+} buttons on the panel.
* Turn on the Plasma at the panel.
* Use the cursor keys on the remote control
2nd GENERATION MODELS
* Put the TV in Stanby.
* Press the {MENU} {SET} {POWER} buttons.
* Use the {MUTE} button to move through modes:
o INFO MODE
o RANGE CHECK MODE
o PICTURE MODE
Reference 1 – Press the {1} button to enter.
Reference 2 – Press the {2} button to enter
Video Box – Press the {3} button to enter.
o INITIALIZE MODE
Sub Video – Press the {1} and {SET} buttons to enter.
Drive Adj – Press the {9} and {SET} buttons to enter.
* Press the {SET} button to save settings.
NOTE: After accessing the Service Menu, all the regular
picture settings will be reset to default values.
Proview
LCD TVs :
* Press the {CH+} {VOL+} buttons.
* The Advanced Menu will be displayed.
LCD MONITORS :
* Turn the power on.
* Unplug the power cable.
* Press and hold the {MENU} button while plugging in
the power cable.
* Then press the {OSD} control button to access menus.
* Use the {MENU} button to access options.
* Press the {MENU} button to save settings.
* To exit, press the {EXIT} button.
#2
* Press and hold the {DOWN} button and then
turn the power off.
* Now press and hold the {UP} button and then
turn the power on.
Roadstar
TVs :
* Press the {MENU} {9} {3} {0} {1} buttons.
* Use the {RED} {GREEN} {BLUE} buttons to access sub-menus
* Use the {PRG+} {PRG-} buttons to select options.
* Use the {VOL+}{VOL-} buttons to change settings.
* To exit, press the {TV/TX} button.
Samsung
* Turn on the TV on and select the input that you want to adjust.
{MUTE} {1} {8} {2} {POWER} buttons.
* The TV will turn On with the Service Menu displayed.
* Select the function and use the {VOL+} button to enter.
#2
* Put the TV in standby mode, then press:
{INFO} {MENU} {MUTE} {POWER} buttons on the remote.
#3
{DISPLAY} {MENU} {MUTE} {POWER} buttons on the remote.
or
{DISPLAY} {P.STD} {MUTE} {POWER} buttons on the remote.
* Use the {CH+} {CH -} buttons to select options.
#4
{P.STD} {AV} {SLEEP} {POWER} buttons on the remote.
or
{P.STD} {HELP} {SLEEP} {POWER} buttons on the remote.
or
{P.STD} {MENU} {SLEEP} {POWER} buttons on the remote.
#5
{P.STD} {AV} {OFF TIMER} {POWER} buttons on the remote.
#6
#7
{SLEEP} {P.STD} {MUTE} {POWER} buttons on the remote.
Sanyo
PLASMAS :
* Press and hold the {MENU} button ON THE TV then
press the {STATUS} button on the remote once.
* Release both buttons.
* Within 2 seconds, press the {MUTE} button on the remote.
* Use the {VOL-} {VOL+} buttons to change settings.
MISC TVs :
* Press and hold the {VOL-} button ON THE TV and
the {TLTXT} button on the remote at the same time.
* Use the {VOL+} button to access sub-menus.
* Press the {MENU} button to return one level.
* To exit, press any other button.
#2
* Press and hold the {MUTE} button on the remote control
while plugging the power cable back into the outlet.
* Keep pressing the {MUTE} button until
the TV powers on with the Service Menu displayed.
* Use the {CH+} {CH-} buttons to select menus.
* Some menus might have sub-addresses. Use the
numeric buttons {0} to {7} to adjust sub-item data.
* Press the {MENU} button or turn the TV off to exit.
#3
* Keep pressing the {VOL -} button until
#4
* Press and hold the {FUNCTION} button on the remote.
* Then press the {PROG+} button on the TV.
* Use the {PRO+} {PROG-} buttons to select options.
* Use the {LEVEL+} {LEVEL-} buttons to change settings.
Schneider
TVs :
or
#2
* Press the {VOL -} button on the TV.
* Then press the {PROG} {-/–} {TV} buttons on the remote.
* Use the {RED} button to save settings.
Sharp
LCD TVs :
TVs :
* Press and hold the {CH+} & {VOL+} buttons.
or
Press and hold the {CH+} & {VOL -} buttons.
* While holding both buttons, plug in the power cable.
* Use the {CH+} {CH -} buttons to select items.
* Use the {VOL+} {VOL -} buttons to adjust values.
* To exit, turn the set off.
Sony
PLASMA / LCD / CRT / RPTV :
* Put the TV in Standby Mode.
* Then press the following buttons on the remote:
{DISPLAY} {5} {VOL+} {POWER}
or
{DISPLAY} {5} {POWER}
or
{DISPLAY} {5} {PICTURE} {POWER}
or
{DISPLAY} {5} {VOL+} {PICTURE} {POWER}
* Use numbers {1} and {4} to select the item to adjust.
* Use numbers {3} and {6} to adjust the value of the data.
* Press {MUTE} then {ENTER} to save new settings.
* The words « WRITE » in red will show up in the upper right corner if saved.
* Turn the TV off to exit the service menu.
Telefunken
TVs :
* Press the {MENU} button on the TV and the
{SETUP} button on the remote at the same time.
* The Service Menu displayed.
* To exit, press the {SETUP} button or turn the TV off.
#2
* Turn the TV on.
* Press the following buttons on the remote:
* {IMAGE} {FACTORY} {POWER} {MUTE} {1} {8} {2} {POWER}
* The TV will power on with the Service Menu displayed.
* Use {VOL+} {VOL -} buttons to select items.
#3
* Then press the {DISPLAY} button on the remote.
* To exit, turn the TV off.
#4
Press and hold the {VOL -} & {PRG -} buttons on the TV.
* Keep both buttons pressed until the TV turns On
#5
* While the TV is on, press the {POWER} button
on the remote control to put TV in standby.
* Turn the TV off using the {POWER} button on the TV.
* Using the buttons on the TV:
* Turn the TV On while pressing the {PRG -} & {VOL -} buttons
#6 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
* Turn the TV on.
Thomson
TVs :
* Use {PR+} {PR -} buttons to select items.
* To exit, turn the TV Off.
#2 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
* While the TV is On, press the {POWER} button
* Turn the TV Off using the {POWER} button on the TV.
Toshiba
LCDs :
* Highlight the « Picture » icon.
* Press the {9} {3} {0} {1} buttons on the remote.
o Options
o Adjustments
o Selections
* Use the {OK} button to access and
navigate through these Modes.
* Use the {VOL +} {VOL-) {P+} {P-} buttons to
MISC TVs :
* Turn the TV on.
* Press the {MUTE} button three times on the remote.
* Press the {MUTE} button again on the remote and hold.
* Then press the {MENU} button on the TV’s front panel.
* There should be a letter « S » on the upper right of the screen.
* Press the {MENU} button on the TV’s front panel again.
* To exit, turn the power off..
* Turn the TV on.
* Press the {MUTE} button twice on the remote.
* Use the {VOL+} and {VOL -} buttons to chnage settings.
* Turn the TV on.
* Press the {MUTE} button on the remote.
* Use the {VOL+} and {VOL -} buttons to change settings.
#4 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Viewsonic
LCDs :
* Turn the TV on.
* Press the {MENU} {9} {9} {1} buttons on the remote.
* Turn the TV on.
* Press the {-/–} {9} {9} {1} buttons on the remote.
* To change pages, press the {MENU} button then
the {-/–} {9} {9} {1} buttons again.
Your adjustments will be memorized.
NOTES:
* You´ll have to make adjustments separately for different
input signals (component, composite, RGB, HDMI).
* Many of the parameters are not accessible.
* Pressing the « User Initialise » Menu will erase
all channels and personal settings.
CRTs :
* Press and hold the {2} button on the remote
while turning the power on.
* Keep the {2} button pressed for at least 4 seconds.
Yamaha
PLASMA DISPLAYS:
PDM-1 50″
* Hold down the {VOL -} button ON THE PLASMA DISPLAY.
* Press the {STATUS} button 3 times on the remote control.
(Status button is the one below Power button)
* The Service Menu (CAT) will be displayed.
(CAT = Computer Aided Test Menu)
* Use the cursors keys on the remote to select a mode.
* And press the action key {} to access the menu.
* To exit each mode, use the {R} button.
* To exit the CAT menu, use the {STATUS} button.
* To exit, press the {POWER} button on the Plasma.
