Bienvenue sur depanetout, forum d’entraide au dépannage électronique › Forums › Schématèque › Composants › Transfo Inverter › Répondre à : Transfo Inverter
3 janvier 2019 à 8 h 30 min
#1987
| Part Number | S. Resistence | P. Resistence | Description | Price | Detail | |||
| 10660347J | 850 Ohm | 1.5 ohm | Replacement Transformer for 614-0257-A Inverter | 11.9900 | Detail | |||
| 1J.26051.001 | 950 Ohm | 0.5 Ohm | Replacement Transformer for 48.L1S04.A01 Inverter | 21.9900 | Detail | |||
| 22.0668.21 | 630 ohm | 1.8 ohm | Replacement Transformer for LCD TV Inverter | 11.9900 | Detail | |||
| 22.0669.21 | 630 ohm | 1.8 ohm | Replacement Transformer for LCD TV Inverter | 11.9900 | Detail | |||
| 22.0895.61 | 780 ohm | 1.7 ohm | New replacement transformer for COM Inverter. | 21.9900 | Detail | |||
| 2874014700 | 610 ohm | 0.3 ohm | New Replacement Transformer for Delta LIPS inverter. | 21.9900 | Detail | |||
| 2874019600 | 650 ohm | 0.3 ohm | New Replacement Transformer for Delta LIPS inverter. | 21.9900 | Detail | |||
| 3324340028EF | 1 K | 1.7 Ohm | New, For LCD TV Inverter | 29.9900 | Detail | |||
| 4001KXXXXXX | 1.5K | 0.8 Ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4001Q75UA14 | 1.46 K | 0.4 Ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4001QXXXXXX | 1.46K | 0.4 ohm | Compatible with part number starts with 4001QXXXXX | 21.9900 | Detail | |||
| 4002P731026 | 1.44K | 0.6 Ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4002P731027 | 1.48 K | 0.6 Ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4002PXXXXXX | 1.48 K | 0.6 Ohm | Compatible with part number starts with 4002PXXXXX | 21.9900 | Detail | |||
| 4002YXXXXXX | 1.2K | 0.5 Ohm | Replacement Transformer for Darfon Inverter | 21.9900 | Detail | |||
| 4003LXXXXXX | 1.10 K | 0.5 Ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4004DXXXXXX | 1.10K | 0.9 ohm | Compatible with part number starts with 4004DXXXXX | 21.9900 | Detail | |||
| 4004L7AH | 1.43 K | 0.7 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4004LXXXXXX | 1.43K | 0.7 ohm | Compatible with part number starts with 4004LXXXXX | 21.9900 | Detail | |||
| 4004QXXXXXX | 1.38K | 0.5 ohm | Compatible with part number starts with 4004QXXXXX | 21.9900 | Detail | |||
| 4004YXXXXXX | 1.10K | 0.3Ohm | Compatible with part number starts with 4004YXXXXX | 21.9900 | Detail | |||
| 4005DXXXXXX | 830 Ohm | 0.6 ohm | Compatible with part number starts with 4005DXXXXX | 21.9900 | Detail | |||
| 4006A502102 | 950 ohm | 1.4 ohm | Compatible with part number starts with 4006AXXXX | 21.9900 | Detail | |||
| 4006A644.135 | 950 ohm | 1.4 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4006A644.139 | 950 ohm | 1.4 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4006A644.215 | 950 ohm | 1.4 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4006A644.243 | 950 ohm | 1.4 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4006A644.253 | 950 ohm | 1.4 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4006A645.135 | 950 ohm | 1.4 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4006A645.139 | 950 ohm | 1.4 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4006A645.207 | 950 ohm | 1.4 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4006A645.209 | 950 ohm | 1.4 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4006AXXXXXX | 950 ohm | 1.4 ohm | Compatible with part number starts with 4006AXXXXX | 21.9900 | Detail | |||
| 4006J544007 | 1.37 K | 0.5 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4006JXXXXXX | 1.37 K | 0.5 ohm | Compatible with part number starts with 4006JXXXXX | 21.9900 | Detail | |||
| 4007D744002 | 1.12 K | 0.7 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4007DXXXXXX | 1.12 K | 0.7 ohm | Compatible with part number starts with 4007DXXXXX | 21.9900 | Detail | |||
| 4009A423011 | 950 ohm | 1.4 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4009A423015 | 950 ohm | 1.4 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4009A427003 | 950 ohm | 1.4 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4009A427007 | 950 ohm | 1.4 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4009A428062 | 950 ohm | 1.4 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4009A450098 | 950 ohm | 1.4 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4009AXXXXXX | 950 ohm | 1.4 ohm | Compatible with part number starts with 4009AXXXXX | 21.9900 | Detail | |||
| 4009LXXXXXX | 1.1 K | 0.5 ohm | Compatible with part number starts with 4009LXXXXX | 21.9900 | Detail | |||
| 4010A807004 | 950 ohm | 1.4 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
| 4010QXXXXXX | 1.1K | 0.5 Ohm | Replacement Transformer for for Darfon Inverter | 21.9900 | Detail | |||
| 4011AXXXXXX | 1.15K | 1.4 ohm | Compatible with part number starts with 4011AXXXX | 21.9900 | Detail | |||
| 4012QXXXXXX | 1.1K | 0.5 Ohm | Replacement Transformer for for Darfon Inverter | 21.9900 | Detail | |||
| 4013L063201 | 1.10 K | 0.5 ohm | New replacement transformer for Darfon Inverter. | 21.9900 | Detail | |||
G
M
T
Fonction Sound est limitée à 200 caractères
| Options : Historique : Commentaires : Donate | Fermer |
