| 0x00000001 |
APC_INDEX_MISMATCH |
| 0x00000002 |
DEVICE_QUEUE_NOT_BUSY |
| 0x00000003 |
INVALID_AFFINITY_SET |
| 0x00000004 |
INVALID_DATA_ACCESS_TRAP |
| 0x00000005 |
INVALID_PROCESS_ATTACH_ATTEMPT |
| 0x00000006 |
INVALID_PROCESS_DETACH_ATTEMPT |
| 0x00000007 |
INVALID_SOFTWARE_INTERRUPT |
| 0x00000008 |
IRQL_NOT_DISPATCH_LEVEL |
| 0x00000009 |
IRQL_NOT_GREATER_OR_EQUAL |
| 0x0000000A |
IRQL_NOT_LESS_OR_EQUAL |
| 0x0000000B |
NO_EXCEPTION_HANDLING_SUPPORT |
| 0x0000000C |
MAXIMUM_WAIT_OBJECTS_EXCEEDED |
| 0x0000000D |
MUTEX_LEVEL_NUMBER_VIOLATION |
| 0x0000000E |
NO_USER_MODE_CONTEXT |
| 0x0000000F |
SPIN_LOCK_ALREADY_OWNED |
| 0x00000010 |
SPIN_LOCK_NOT_OWNED |
| 0x00000011 |
THREAD_NOT_MUTEX_OWNER |
| 0x00000012 |
TRAP_CAUSE_UNKNOWN |
| 0x00000013 |
EMPTY_THREAD_REAPER_LIST |
| 0x00000014 |
CREATE_DELETE_LOCK_NOT_LOCKED |
| 0x00000015 |
LAST_CHANCE_CALLED_FROM_KMODE |
| 0x00000016 |
CID_HANDLE_CREATION |
| 0x00000017 |
CID_HANDLE_DELETION |
| 0x00000018 |
REFERENCE_BY_POINTER |
| 0x00000019 |
BAD_POOL_HEADER |
| 0x0000001A |
MEMORY_MANAGEMENT |
| 0x0000001B |
PFN_SHARE_COUNT |
| 0x0000001C |
PFN_REFERENCE_COUNT |
| 0x0000001D |
NO_SPIN_LOCK_AVAILABLE |
| 0x0000001E |
KMODE_EXCEPTION_NOT_HANDLED |
| 0x0000001F |
SHARED_RESOURCE_CONV_ERROR |
| 0x00000020 |
KERNEL_APC_PENDING_DURING_EXIT |
| 0x00000021 |
QUOTA_UNDERFLOW |
| 0x00000022 |
FILE_SYSTEM |
| 0x00000023 |
FAT_FILE_SYSTEM |
| 0x00000024 |
NTFS_FILE_SYSTEM |
| 0x00000025 |
NPFS_FILE_SYSTEM |
| 0x00000026 |
CDFS_FILE_SYSTEM |
| 0x00000027 |
RDR_FILE_SYSTEM |
| 0x00000028 |
CORRUPT_ACCESS_TOKEN |
| 0x00000029 |
SECURITY_SYSTEM |
| 0x0000002A |
INCONSISTENT_IRP |
| 0x0000002B |
PANIC_STACK_SWITCH |
| 0x0000002C |
PORT_DRIVER_INTERNAL |
| 0x0000002D |
SCSI_DISK_DRIVER_INTERNAL |
| 0x0000002E |
DATA_BUS_ERROR |
| 0x0000002F |
INSTRUCTION_BUS_ERROR |
| 0x00000030 |
SET_OF_INVALID_CONTEXT |
| 0x00000031 |
PHASE0_INITIALIZATION_FAILED |
| 0x00000032 |
PHASE1_INITIALIZATION_FAILED |
| 0x00000033 |
UNEXPECTED_INITIALIZATION_CALL |
| 0x00000034 |
CACHE_MANAGER |
| 0x00000035 |
NO_MORE_IRP_STACK_LOCATIONS |
| 0x00000036 |
DEVICE_REFERENCE_COUNT_NOT_ZERO |
| 0x00000037 |
FLOPPY_INTERNAL_ERROR |
| 0x00000038 |
SERIAL_DRIVER_INTERNAL |
| 0x00000039 |
SYSTEM_EXIT_OWNED_MUTEX |
| 0x0000003A |
SYSTEM_UNWIND_PREVIOUS_USER |
| 0x0000003B |
SYSTEM_SERVICE_EXCEPTION |
| 0x0000003C |
INTERRUPT_UNWIND_ATTEMPTED |
| 0x0000003D |
INTERRUPT_EXCEPTION_NOT_HANDLED |
| 0x0000003E |
MULTIPROCESSOR_CONFIGURATION_NOT_SUPPORTED |
| 0x0000003F |
NO_MORE_SYSTEM_PTES |
| 0x00000040 |
TARGET_MDL_TOO_SMALL |
| 0x00000041 |
MUST_SUCCEED_POOL_EMPTY |
| 0x00000042 |
ATDISK_DRIVER_INTERNAL |
| 0x00000043 |
NO_SUCH_PARTITION |
| 0x00000044 |
MULTIPLE_IRP_COMPLETE_REQUESTS |
| 0x00000045 |
INSUFFICIENT_SYSTEM_MAP_REGS |
| 0x00000046 |
DEREF_UNKNOWN_LOGON_SESSION |
| 0x00000047 |
| 0x00000048 |
CANCEL_STATE_IN_COMPLETED_IRP |
| 0x00000049 |
PAGE_FAULT_WITH_INTERRUPTS_OFF |
| 0x0000004A |
IRQL_GT_ZERO_AT_SYSTEM_SERVICE |
| 0x0000004B |
STREAMS_INTERNAL_ERROR |
| 0x0000004C |
FATAL_UNHANDLED_HARD_ERROR |
| 0x0000004D |
NO_PAGES_AVAILABLE |
| 0x0000004E |
PFN_LIST_CORRUPT |
| 0x0000004F |
NDIS_INTERNAL_ERROR |
| 0x00000050 |
PAGE_FAULT_IN_NONPAGED_AREA |
| 0x00000051 |
REGISTRY_ERROR |
| 0x00000052 |
MAILSLOT_FILE_SYSTEM |
| 0x00000053 |
NO_BOOT_DEVICE |
| 0x00000054 |
LM_SERVER_INTERNAL_ERROR |
| 0x00000055 |
DATA_COHERENCY_EXCEPTION |
| 0x00000056 |
INSTRUCTION_COHERENCY_EXCEPTION |
| 0x00000057 |
XNS_INTERNAL_ERROR |
| 0x00000058 |
FTDISK_INTERNAL_ERROR |
| 0x00000059 |
PINBALL_FILE_SYSTEM |
| 0x0000005A |
CRITICAL_SERVICE_FAILED |
| 0x0000005B |
SET_ENV_VAR_FAILED |
| 0x0000005C |
HAL_INITIALIZATION_FAILED |
| 0x0000005D |
UNSUPPORTED_PROCESSOR |
| 0x0000005E |
OBJECT_INITIALIZATION_FAILED |
| 0x0000005F |
SECURITY_INITIALIZATION_FAILED |
| 0x00000060 |
PROCESS_INITIALIZATION_FAILED |
| 0x00000061 |
HAL1_INITIALIZATION_FAILED |
| 0x00000062 |
OBJECT1_INITIALIZATION_FAILED |
| 0x00000063 |
SECURITY1_INITIALIZATION_FAILED |
| 0x00000064 |
SYMBOLIC_INITIALIZATION_FAILED |
| 0x00000065 |
MEMORY1_INITIALIZATION_FAILED |
| 0x00000066 |
CACHE_INITIALIZATION_FAILED |
| 0x00000067 |
CONFIG_INITIALIZATION_FAILED |
| 0x00000068 |
FILE_INITIALIZATION_FAILED |
| 0x00000069 |
IO1_INITIALIZATION_FAILED |
| 0x0000006A |
LPC_INITIALIZATION_FAILED |
| 0x0000006B |
PROCESS1_INITIALIZATION_FAILED |
| 0x0000006C |
REFMON_INITIALIZATION_FAILED |
| 0x0000006D |
SESSION1_INITIALIZATION_FAILED |
| 0x0000006E |
SESSION2_INITIALIZATION_FAILED |
| 0x0000006F |
SESSION3_INITIALIZATION_FAILED |
| 0x00000070 |
SESSION4_INITIALIZATION_FAILED |
| 0x00000071 |
SESSION5_INITIALIZATION_FAILED |
| 0x00000072 |
ASSIGN_DRIVE_LETTERS_FAILED |
| 0x00000073 |
CONFIG_LIST_FAILED |
| 0x00000074 |
BAD_SYSTEM_CONFIG_INFO |
| 0x00000075 |
CANNOT_WRITE_CONFIGURATION |
| 0x00000076 |
PROCESS_HAS_LOCKED_PAGES |
| 0x00000077 |
KERNEL_STACK_INPAGE_ERROR |
| 0x00000078 |
PHASE0_EXCEPTION |
| 0x00000079 |
MISMATCHED_HAL |
| 0x0000007A |
KERNEL_DATA_INPAGE_ERROR |
| 0x0000007B |
INACCESSIBLE_BOOT_DEVICE |
| 0x0000007C |
BUGCODE_NDIS_DRIVER |
| 0x0000007D |
INSTALL_MORE_MEMORY |
| 0x0000007E |
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED |
| 0x0000007F |
UNEXPECTED_KERNEL_MODE_TRAP |
| 0x00000080 |
NMI_HARDWARE_FAILURE |
| 0x00000081 |
SPIN_LOCK_INIT_FAILURE |
| 0x00000082 |
DFS_FILE_SYSTEM |
| 0x00000085 |
SETUP_FAILURE |
| 0x0000008B |
MBR_CHECKSUM_MISMATCH |
| 0x0000008E |
KERNEL_MODE_EXCEPTION_NOT_HANDLED |
| 0x0000008F |
PP0_INITIALIZATION_FAILED |
| 0x00000090 |
PP1_INITIALIZATION_FAILED |
| 0x00000092 |
UP_DRIVER_ON_MP_SYSTEM |
| 0x00000093 |
INVALID_KERNEL_HANDLE |
| 0x00000094 |
KERNEL_STACK_LOCKED_AT_EXIT |
| 0x00000096 |
INVALID_WORK_QUEUE_ITEM |
| 0x00000097 |
BOUND_IMAGE_UNSUPPORTED |
| 0x00000098 |
END_OF_NT_EVALUATION_PERIOD |
| 0x00000099 |
INVALID_REGION_OR_SEGMENT |
| 0x0000009A |
SYSTEM_LICENSE_VIOLATION |
| 0x0000009B |
UDFS_FILE_SYSTEM |
| 0x0000009C |
MACHINE_CHECK_EXCEPTION |
| 0x0000009E |
USER_MODE_HEALTH_MONITOR |
| 0x0000009F |
DRIVER_POWER_STATE_FAILURE |
| 0x000000A0 |
INTERNAL_POWER_ERROR |
| 0x000000A1 |
PCI_BUS_DRIVER_INTERNAL |
| 0x000000A2 |
MEMORY_IMAGE_CORRUPT |
| 0x000000A3 |
ACPI_DRIVER_INTERNAL |
| 0x000000A4 |
CNSS_FILE_SYSTEM_FILTER |
| 0x000000A5 |
ACPI_BIOS_ERROR |
| 0x000000A7 |
BAD_EXHANDLE |
| 0x000000AB |
SESSION_HAS_VALID_POOL_ON_EXIT |
| 0x000000AC |
HAL_MEMORY_ALLOCATION |
| 0x000000AD |
VIDEO_DRIVER_DEBUG_REPORT_REQUEST |
| 0x000000B1 |
BGI_DETECTED_VIOLATION |
| 0x000000B4 |
VIDEO_DRIVER_INIT_FAILURE |
| 0x000000B8 |
ATTEMPTED_SWITCH_FROM_DPC |
| 0x000000B9 |
CHIPSET_DETECTED_ERROR |
| 0x000000BA |
SESSION_HAS_VALID_VIEWS_ON_EXIT |
| 0x000000BB |
NETWORK_BOOT_INITIALIZATION_FAILED |
| 0x000000BC |
NETWORK_BOOT_DUPLICATE_ADDRESS |
| 0x000000BD |
INVALID_HIBERNATED_STATE |
| 0x000000BE |
ATTEMPTED_WRITE_TO_READONLY_MEMORY |
| 0x000000BF |
MUTEX_ALREADY_OWNED |
| 0x000000C1 |
SPECIAL_POOL_DETECTED_MEMORY_CORRUPTION |
| 0x000000C2 |
BAD_POOL_CALLER |
| 0x000000C4 |
DRIVER_VERIFIER_DETECTED_VIOLATION |
| 0x000000C5 |
DRIVER_CORRUPTED_EXPOOL |
| 0x000000C6 |
DRIVER_CAUGHT_MODIFYING_FREED_POOL |
| 0x000000C7 |
TIMER_OR_DPC_INVALID |
| 0x000000C8 |
IRQL_UNEXPECTED_VALUE |
| 0x000000C9 |
DRIVER_VERIFIER_IOMANAGER_VIOLATION |
| 0x000000CA |
PNP_DETECTED_FATAL_ERROR |
| 0x000000CB |
DRIVER_LEFT_LOCKED_PAGES_IN_PROCESS |
| 0x000000CC |
PAGE_FAULT_IN_FREED_SPECIAL_POOL |
| 0x000000CD |
PAGE_FAULT_BEYOND_END_OF_ALLOCATION |
| 0x000000CE |
DRIVER_UNLOADED_WITHOUT_CANCELLING_PENDING_OPERATIONS |
| 0x000000CF |
TERMINAL_SERVER_DRIVER_MADE_INCORRECT_MEMORY_REFERENCE |
| 0x000000D0 |
DRIVER_CORRUPTED_MMPOOL |
| 0x000000D1 |
DRIVER_IRQL_NOT_LESS_OR_EQUAL |
| 0x000000D2 |
BUGCODE_ID_DRIVER |
| 0x000000D3 |
DRIVER_PORTION_MUST_BE_NONPAGED |
| 0x000000D4 |
SYSTEM_SCAN_AT_RAISED_IRQL_CAUGHT_IMPROPER_DRIVER_UNLOAD |
| 0x000000D5 |
DRIVER_PAGE_FAULT_IN_FREED_SPECIAL_POOL |
| 0x000000D6 |
DRIVER_PAGE_FAULT_BEYOND_END_OF_ALLOCATION |
| 0x000000D7 |
DRIVER_UNMAPPING_INVALID_VIEW |
| 0x000000D8 |
DRIVER_USED_EXCESSIVE_PTES |
| 0x000000D9 |
LOCKED_PAGES_TRACKER_CORRUPTION |
| 0x000000DA |
SYSTEM_PTE_MISUSE |
| 0x000000DB |
DRIVER_CORRUPTED_SYSPTES |
| 0x000000DC |
DRIVER_INVALID_STACK_ACCESS |
| 0x000000DE |
POOL_CORRUPTION_IN_FILE_AREA |
| 0x000000DF |
IMPERSONATING_WORKER_THREAD |
| 0x000000E0 |
ACPI_BIOS_FATAL_ERROR |
| 0x000000E1 |
WORKER_THREAD_RETURNED_AT_BAD_IRQL |
| 0x000000E2 |
MANUALLY_INITIATED_CRASH |
| 0x000000E3 |
RESOURCE_NOT_OWNED |
| 0x000000E4 |
WORKER_INVALID |
| 0x000000E6 |
DRIVER_VERIFIER_DMA_VIOLATION |
| 0x000000E7 |
INVALID_FLOATING_POINT_STATE |
| 0x000000E8 |
INVALID_CANCEL_OF_FILE_OPEN |
| 0x000000E9 |
ACTIVE_EX_WORKER_THREAD_TERMINATION |
| 0x000000EA |
THREAD_STUCK_IN_DEVICE_DRIVER |
| 0x000000EB |
DIRTY_MAPPED_PAGES_CONGESTION |
| 0x000000EC |
SESSION_HAS_VALID_SPECIAL_POOL_ON_EXIT |
| 0x000000ED |
UNMOUNTABLE_BOOT_VOLUME |
| 0x000000EF |
CRITICAL_PROCESS_DIED |
| 0x000000F1 |
SCSI_VERIFIER_DETECTED_VIOLATION |
| 0x000000F2 |
HARDWARE_INTERRUPT_STORM |
| 0x000000F3 |
DISORDERLY_SHUTDOWN |
| 0x000000F4 |
CRITICAL_OBJECT_TERMINATION |
| 0x000000F5 |
FLTMGR_FILE_SYSTEM |
| 0x000000F6 |
PCI_VERIFIER_DETECTED_VIOLATION |
| 0x000000F7 |
DRIVER_OVERRAN_STACK_BUFFER |
| 0x000000F8 |
RAMDISK_BOOT_INITIALIZATION_FAILED |
| 0x000000F9 |
DRIVER_RETURNED_STATUS_REPARSE_FOR_VOLUME_OPEN |
| 0x000000FA |
HTTP_DRIVER_CORRUPTED |
| 0x000000FC |
ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY |
| 0x000000FD |
DIRTY_NOWRITE_PAGES_CONGESTION |
| 0x000000FE |
BUGCODE_USB_DRIVER |
| 0x000000FF |
RESERVE_QUEUE_OVERFLOW |
| 0x00000100 |
LOADER_BLOCK_MISMATCH |
| 0x00000101 |
CLOCK_WATCHDOG_TIMEOUT |
| 0x00000102 |
DPC_WATCHDOG_TIMEOUT |
| 0x00000103 |
MUP_FILE_SYSTEM |
| 0x00000104 |
AGP_INVALID_ACCESS |
| 0x00000105 |
AGP_GART_CORRUPTION |
| 0x00000106 |
AGP_ILLEGALLY_REPROGRAMMED |
| 0x00000108 |
THIRD_PARTY_FILE_SYSTEM_FAILURE |
| 0x00000109 |
CRITICAL_STRUCTURE_CORRUPTION |
| 0x0000010A |
APP_TAGGING_INITIALIZATION_FAILED |
| 0x0000010C |
FSRTL_EXTRA_CREATE_PARAMETER_VIOLATION |
| 0x0000010D |
WDF_VIOLATION |
| 0x0000010E |
VIDEO_MEMORY_MANAGEMENT_INTERNAL |
| 0x0000010F |
RESOURCE_MANAGER_EXCEPTION_NOT_HANDLED |
| 0x00000111 |
RECURSIVE_NMI |
| 0x00000112 |
MSRPC_STATE_VIOLATION |
| 0x00000113 |
VIDEO_DXGKRNL_FATAL_ERROR |
| 0x00000114 |
VIDEO_SHADOW_DRIVER_FATAL_ERROR |
| 0x00000115 |
AGP_INTERNAL |
| 0x00000116 |
VIDEO_TDR_ERROR |
| 0x00000117 |
VIDEO_TDR_TIMEOUT_DETECTED |
| 0x00000119 |
VIDEO_SCHEDULER_INTERNAL_ERROR |
| 0x0000011A |
EM_INITIALIZATION_FAILURE |
| 0x0000011B |
DRIVER_RETURNED_HOLDING_CANCEL_LOCK |
| 0x0000011C |
ATTEMPTED_WRITE_TO_CM_PROTECTED_STORAGE |
| 0x0000011D |
EVENT_TRACING_FATAL_ERROR |
| 0x0000011E |
TOO_MANY_RECURSIVE_FAULTS |
| 0x0000011F |
INVALID_DRIVER_HANDLE |
| 0x00000120 |
BITLOCKER_FATAL_ERROR |
| 0x00000121 |
DRIVER_VIOLATION |
| 0x00000122 |
WHEA_INTERNAL_ERROR |
| 0x00000123 |
CRYPTO_SELF_TEST_FAILURE |
| 0x00000124 |
WHEA_UNCORRECTABLE_ERROR |
| 0x00000125 |
NMR_INVALID_STATE |
| 0x00000126 |
NETIO_INVALID_POOL_CALLER |
| 0x00000127 |
PAGE_NOT_ZERO |
| 0x00000128 |
WORKER_THREAD_RETURNED_WITH_BAD_IO_PRIORITY |
| 0x00000129 |
WORKER_THREAD_RETURNED_WITH_BAD_PAGING_IO_PRIORITY |
| 0x0000012A |
MUI_NO_VALID_SYSTEM_LANGUAGE |
| 0x0000012B |
FAULTY_HARDWARE_CORRUPTED_PAGE |
| 0x0000012C |
EXFAT_FILE_SYSTEM |
| 0x0000012D |
VOLSNAP_OVERLAPPED_TABLE_ACCESS |
| 0x0000012E |
INVALID_MDL_RANGE |
| 0x0000012F |
VHD_BOOT_INITIALIZATION_FAILED |
| 0x00000130 |
DYNAMIC_ADD_PROCESSOR_MISMATCH |
| 0x00000131 |
INVALID_EXTENDED_PROCESSOR_STATE |
| 0x00000132 |
RESOURCE_OWNER_POINTER_INVALID |
| 0x00000133 |
DPC_WATCHDOG_VIOLATION |
| 0x00000134 |
DRIVE_EXTENDER |
| 0x00000135 |
REGISTRY_FILTER_DRIVER_EXCEPTION |
| 0x00000136 |
VHD_BOOT_HOST_VOLUME_NOT_ENOUGH_SPACE |
| 0x00000137 |
WIN32K_HANDLE_MANAGER |
| 0x00000138 |
GPIO_CONTROLLER_DRIVER_ERROR |
| 0x00000139 |
KERNEL_SECURITY_CHECK_FAILURE |
| 0x0000013A |
KERNEL_MODE_HEAP_CORRUPTION |
| 0x0000013B |
PASSIVE_INTERRUPT_ERROR |
| 0x0000013C |
INVALID_IO_BOOST_STATE |
| 0x0000013D |
CRITICAL_INITIALIZATION_FAILURE |
| 0x00000140 |
STORAGE_DEVICE_ABNORMALITY_DETECTED |
| 0x00000141 |
VIDEO_ENGINE_TIMEOUT_DETECTED |
| 0x00000142 |
VIDEO_TDR_APPLICATION_BLOCKED |
| 0x00000143 |
PROCESSOR_DRIVER_INTERNAL |
| 0x00000144 |
BUGCODE_USB3_DRIVER |
| 0x00000145 |
SECURE_BOOT_VIOLATION |
| 0x00000147 |
ABNORMAL_RESET_DETECTED |
| 0x00000149 |
REFS_FILE_SYSTEM |
| 0x0000014A |
KERNEL_WMI_INTERNAL |
| 0x0000014B |
SOC_SUBSYSTEM_FAILURE |
| 0x0000014C |
FATAL_ABNORMAL_RESET_ERROR |
| 0x0000014D |
EXCEPTION_SCOPE_INVALID |
| 0x0000014E |
SOC_CRITICAL_DEVICE_REMOVED |
| 0x0000014F |
PDC_WATCHDOG_TIMEOUT |
| 0x00000150 |
TCPIP_AOAC_NIC_ACTIVE_REFERENCE_LEAK |
| 0x00000151 |
UNSUPPORTED_INSTRUCTION_MODE |
| 0x00000152 |
INVALID_PUSH_LOCK_FLAGS |
| 0x00000153 |
KERNEL_LOCK_ENTRY_LEAKED_ON_THREAD_TERMINATION |
| 0x00000154 |
UNEXPECTED_STORE_EXCEPTION |
| 0x00000155 |
OS_DATA_TAMPERING |
| 0x00000156 |
WINSOCK_DETECTED_HUNG_CLOSESOCKET_LIVEDUMP |
| 0x00000157 |
KERNEL_THREAD_PRIORITY_FLOOR_VIOLATION |
| 0x00000158 |
ILLEGAL_IOMMU_PAGE_FAULT |
| 0x00000159 |
HAL_ILLEGAL_IOMMU_PAGE_FAULT |
| 0x0000015A |
SDBUS_INTERNAL_ERROR |
| 0x0000015B |
WORKER_THREAD_RETURNED_WITH_SYSTEM_PAGE_PRIORITY_ACTIVE |
| 0x0000015C |
PDC_WATCHDOG_TIMEOUT_LIVEDUMP |
| 0x0000015F |
CONNECTED_STANDBY_WATCHDOG_TIMEOUT_LIVEDUMP |
| 0x00000160 |
WIN32K_ATOMIC_CHECK_FAILURE |
| 0x00000161 |
LIVE_SYSTEM_DUMP |
| 0x00000162 |
KERNEL_AUTO_BOOST_INVALID_LOCK_RELEASE |
| 0x00000163 |
WORKER_THREAD_TEST_CONDITION |
| 0x00000164 |
WIN32K_CRITICAL_FAILURE |
| 0x0000016C |
INVALID_RUNDOWN_PROTECTION_FLAGS |
| 0x0000016D |
INVALID_SLOT_ALLOCATOR_FLAGS |
| 0x0000016E |
ERESOURCE_INVALID_RELEASE |
| 0x00000175 |
PREVIOUS_FATAL_ABNORMAL_RESET_ERROR |
| 0x00000178 |
ELAM_DRIVER_DETECTED_FATAL_ERROR |
| 0x0000017B |
PROFILER_CONFIGURATION_ILLEGAL |
| 0x00000187 |
VIDEO_DWMINIT_TIMEOUT_FALLBACK_BDD |
| 0x00000188 |
CLUSTER_CSVFS_LIVEDUMP |
| 0x00000189 |
BAD_OBJECT_HEADER |
| 0x0000018B |
SECURE_KERNEL_ERROR |
| 0x0000018E |
KERNEL_PARTITION_REFERENCE_VIOLATION |
| 0x00000190 |
WIN32K_CRITICAL_FAILURE_LIVEDUMP |
| 0x00000191 |
PF_DETECTED_CORRUPTION |
| 0x00000192 |
KERNEL_AUTO_BOOST_LOCK_ACQUISITION_WITH_RAISED_IRQL |
| 0x00000193 |
VIDEO_DXGKRNL_LIVEDUMP |
| 0x00000195 |
SMB_SERVER_LIVEDUMP |
| 0x00000196 |
LOADER_ROLLBACK_DETECTED |
| 0x00000197 |
WIN32K_SECURITY_FAILURE |
| 0x00000198 |
UFX_LIVEDUMP |
| 0x00000199 |
KERNEL_STORAGE_SLOT_IN_USE |
| 0x0000019A |
WORKER_THREAD_RETURNED_WHILE_ATTACHED_TO_SILO |
| 0x0000019B |
TTM_FATAL_ERROR |
| 0x0000019C |
WIN32K_POWER_WATCHDOG_TIMEOUT |
| 0x0000019D |
CLUSTER_SVHDX_LIVEDUMP |
| 0x000001A3 |
CALL_HAS_NOT_RETURNED_WATCHDOG_TIMEOUT_LIVEDUMP |
| 0x000001A4 |
DRIPS_SW_HW_DIVERGENCE_LIVEDUMP |
| 0x000001C4 |
DRIVER_VERIFIER_DETECTED_VIOLATION_LIVEDUMP |
| 0x000001C5 |
IO_THREADPOOL_DEADLOCK_LIVEDUMP |
| 0x000001C8 |
MANUALLY_INITIATED_POWER_BUTTON_HOLD |
| 0x000001CC |
EXRESOURCE_TIMEOUT_LIVEDUMP |
| 0x000001CD |
INVALID_CALLBACK_STACK_ADDRESS |
| 0x000001CE |
INVALID_KERNEL_STACK_ADDRESS |
| 0x000001CF |
HARDWARE_WATCHDOG_TIMEOUT |
| 0x000001D0 |
CPI_FIRMWARE_WATCHDOG_TIMEOUT |
| 0x000001D1 |
TELEMETRY_ASSERTS_LIVEDUMP |
| 0x000001D2 |
WORKER_THREAD_INVALID_STATE |
| 0x000001D3 |
WFP_INVALID_OPERATION |
| 0x000001D4 |
UCMUCSI_LIVEDUMP |
| 0x00000356 |
XBOX_ERACTRL_CS_TIMEOUT |
| 0x00000BFE |
BC_BLUETOOTH_VERIFIER_FAULT |
| 0x00000BFF |
BC_BTHMINI_VERIFIER_FAULT |
| 0x00020001 |
HYPERVISOR_ERROR |
| 0x1000007E |
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M |
| 0x1000007F |
UNEXPECTED_KERNEL_MODE_TRAP_M |
| 0x1000008E |
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M |
| 0x100000EA |
THREAD_STUCK_IN_DEVICE_DRIVER_M |
| 0x4000008A |
THREAD_TERMINATE_HELD_MUTEX |
| 0xC0000218 |
STATUS_CANNOT_LOAD_REGISTRY_FILE |
| 0xC000021A |
STATUS_SYSTEM_PROCESS_TERMINATED |
| 0xC0000221 |
STATUS_IMAGE_CHECKSUM_MISMATCH |
| 0xDEADDEAD |
MANUALLY_INITIATED_CRASH1 |
