Répondre à : Mode Service plusieurs Marques
#2263
PHILIPS
Log into the service menu :
# c is rapidly gaining remote 062596i (i- button « info »,)
# window appears with a warning in English.
Warning: Access only to employees of service centers.
Unauthorized access may terminate the guarantee of your TV.
# Do you want to go – simply press the Menu button on the remote . Exiting the Menu – click the red button on the remote.
Useful information
1. hours worked . SM -> Operation hours
2. type matrix. SM -> Options -> Display -> Screen
# 062. LCD LPL WX5 SLB1 32 « . LPL – native filipsovskaya matrix. The most desirable option.
TOSHIBA
# Turn on TV and press the MUTE button on the remote . Further MENU on the TV casing and simultaneously MUTE on the remote.
# press the  » 9  » once and see the top line on time.
# pressing  » 9  » several times looking type of matrix .
# Press the AV input call splash of blue, red and green colors.
Warning: Press « 2 » do not press in any case ! (reason not specified, but unconfirmed reports included calibration mode, white)
Exit – turn off TV -click  » Network.  »
SAMSUNG
For all LCD and PDP TV in Europe – a way to enter the Service Menu is universal
When TV is turned off rapidly and continuously press on the remote control keys INFO – MENU – MUTE – POWER
TV less than 25  » sometimes works the American way MUTE – 1 – 8 – 2 – POWER
Log in Service Menu possible only at very high speed pressing all the buttons for 1-2 seconds.
# Move – Enter – enter the submenu , Menu – access to the upper level, up / down – move .
# How to change – think a hundred times , save the settings that were – they are not restored by Reset, left / right – change
Warning: Do not enter the Calibrate and Reset in general, if you do not know why you need it !
# Exit – turn off the TV .
To enter the Advanced Menu – Dial 0000.
Immediately prepare to re- issuing all the custom settings – they will be exposed by default.
# In the engineering menus Panel On Time (Hour) – time between panels.
What can change or adjust in Service Menu?
# Option table is responsible for the overall configuration of the entrance and the telly does not depend on !
# Dimm Type / Type – Information about the matrix .
# Ready responsible for the DTV tuner (OFF – enabled , ON – OFF)
# Shop Mode – enables or disables the magazine mode.
# Adjust – after 2008, hid in the Advanced Menu.
# Video Mute Time – Reduce the value for the quickening of channel switching .
SHARP
# Click on MENU button
# We go to the audio settings .
# Later in the balance
# Rapidly gaining on the remote control -> 0532
# TV dolzhekn go to sevisny mode.
# To exit the SM press the  » network  » on the remote.
2nd version of the entrance to the service menu :
# TV must be switched off.
# Press and hold the « VOLUME – » and « MENU » on the TV and turn it on the button « ON / OFF ».
Button « VOLUME – » and « MENU » do not let until TV lights up the screen. In the upper left corner should be lighted sign.
# Press the buttons simultaneously « PR- » and « MENU ».
# Further navigation panel.
To exit the service menu to turn off the TV button « ON / OFF » on the TV.
# Press and hold the « VOLUME – » and « MENU » on the TV switch on the TV button « ON / OFF ».
The third version of the entrance to the service menu :
# Turn off the TV button « Power »
# Push the TV button, « Vol – » and « INPUT »
# Hold them turn on the TV . In the left corner appear bukvochki .
# Press and hold the « VOLUME – » and « INPUT » on the TV switch on the TV button « ON / OFF ».
Button « VOLUME – » and « INPUT » not to let TV do not shine until the screen.
Sony TV Service Menu Code
Plasma / LCD / CRT / RPTV :
# Using the remote control:
# Turn the TV off.
# Press {DISPLAY} {5} {VOL+} {POWER ON} buttons.
or
Press {DISPLAY} {5} {POWER ON} buttons.
# The Service Menu will be displayed.
# Use numbers {1} and {4} to select the item to adjust.
# Use numbers {3} and {6} to adjust the value of the data.
# Press {MUTE} then {ENTER} to save new settings.
# The words « WRITE » in red will show up in the upper right corner if saved.
# Turn the TV off to exit the service menu.
PROJECTORS :
* Service Menu :
* Using the remote control
* Press {ENTER} {ENTER} {UP ARROW} {DOWN ARROW} {ENTER}.
* Then {UP ARROW} when it asks: « Do you want to enter the Service mode? ».
* Factory Mode :
* Press {ENTER} {ENTER} {LEFT ARROW} {ENTER}.
* Then {UP ARROW} when it asks: « Do you want to enter the Factory Mode? ».
* Any additional menus usually pop up under the main INFORMATION menu.
Service Menu Key Sequence:
* Access « Menu » and make sure « Status » is On.
* Exit the « Menu ».
* Service Menu :
* Select « Yes » when it asks: « Do you want to enter the Service Mode? ».
* Factory Mode :
* Select « Yes » when it asks: « Do you want to enter the Factory Mode
menu service LCD PhilipS
code pour rentrer dans le menu service
par contre ta reference est inconnu chez philips il existe 2 code
tapez a l’aide de la telecommande
la sequence 0 6 2 5 9 6 puis la touche OSD
( un carre avec un I+]
ou tapez a l’aide de la telecommande
la sequence 1 2 3 6 5 4 une mire apparaitra ensuite
tu arrivera dans le menu service
AKAI CT-2119PD/PDT, U2E/Y2/Y2E
On the TV at the same time press the button VOL + and VOL-and hold them, turn on the TV.
Exit – (POWER OFF)
AKAI CT2161 CT2565 CT2567 CT2865 CT2867, Chassis SP
On the keypad press the button – (MUTE) (OK) (TV). Data record (OK). Out – (TV)
AKAI CT2899, 7171 Processor CCU11 \ 12, chassis B-E2
For CCU 11 (. °) (C) (H), CCU 12 for a screwdriver Press contact in the hole
about the keyboard and press the right button (S). Exit – (LOAD)
AKIRA CT-14PF9
On the keypad to dial: (MENU) (MENU) (V. WIEV) (MUTE) (SLEEP) – turning the pages. Exit – (MENU)
AKIRA CT-21HS9C (S) CPU LC863324A
Login: Menu – Menu – Q. View – Mute
AKIRA CT-2155, Processor VESTEL 19V1, Chassis 11AK19PRO
Press the blue button to enter the SETUP menu to press buttons 4, 7, 2, 5.
AKIRA CT-2155, CT-2160 Processor: VESTEL 19V1.0NT
The entrance to the service. Push MENU (INSTALL), put cursor on « Settings ».
Then click successively 4 => 7 = 2 => 5
AKURA, CROWN, MINOKA CX25/26/34 CR20NT CR1406FT MK1498N / N MK2183 / N
Conclusion 8 processor TVPO2066 D05/047 to activate
service mode. On-board TV is a special button S009. Clicking on it simultaneously with a button (DISPLAY) on the RC
included in the service menu. Exit – (TV / TEXT)
ALLSTAR 3750
Turning off the Hotel Mode: Select the program 38. At the same time hold for 3 seconds STORE and CONTROL + on
panel TV.
Enable Hotel Mode: Select the program 38. At the same time hold for 3 seconds STORE and CONTROL-panel TV.
ARAY ACT2130 Processor – LC863328A, video processor – LA76810A
Log into the service mode: Push button hidden (FACTORY) on the remote control, it also switches the menu.
chip remote SC7461-103 (pins 2 and 16)
AUDIOTON 5502 Chassis 10.3 90 ° MONO
Turning off the protection of children: Press UP & DOWN buttons together on tv’s local control
and then switch on. You will see SERVICE MODE. Do not press any button, just power off the set, then on ..
Enabling the service menu: Press UP & DOWN buttons together on tv’s local control and then switch on
BANG & OLUFSEN LX4500/5500 L4500/5500 MX3500/5500
Prepare
your TV, set: Brightness 32 Saturation 32, contrast 44. Click (TV) on
the remote control and lock for a minute (60 seconds) click PCB5, which
is located close to Terminals VM. Exit – (STOP) or (POWER OFF)
BEKO, Processor SDA20563-A512/A514, Chassis AR-3
While holding down the button on the TV (PROG-) (PROG +) toggle switch on the TV network. Exit – (POWER OFF)
BEKO CTV, processor SAA5563, Chassis 14.1
Close a chip RC legs 10 and 17. Exit – Close the remote control at the chip legs 10 and 17.
BEKO chassis 12.6 Processor SDA5535A049
  • PICTURE MENU
  • 8500″
  • EXIT « 850 »
BEKO chassis 12.7 Processor SDA5535A056
  • PICTURE MENU
  • « 9301 »
  • EXIT « 0 »
BLAUPUNKT IS63 (72) 1953 DIGITAL PRO, CPU MC68HC11F1, chassis FM640.40
Starting
the internal memory of the processor. Shorted to ground (earth) pin 1
processor (contact MP2) and turn on the TV to the network. Services (i)
(E). Output (i)
BLAUPUNKT MM63-13VT MM63-14HT, processor ZC88649P ZC88644P ZC424701, Chassis FM-240/00
Hold down the (i) to enable remote power switch. Exit – (POWER OFF).
BLAUPUNKT MS70-100 Digital PRO, CS82-100 Digital PRO, Chassis FM600.70 FM600.71
Click
(i) on the remote. Choose the position PROGRAMMIER OPTIONEN press (ME)
(AUX). Choose the position of SERVICE MODE Press (ME) (3) (2) (0) (0).
Exit – (TV).
BLAUPUNKT MS70-76VT, Processor HD6305Y1B80P, chassis FM100-30CTS
  • Turn off the TV with remote control
  • Include a remote control, keeping ME on the local panel TV.
Adjustment using the (+) (-) on the keypad. TB: Brightness (on TV) –
vertical size, saturation (on TV) – the size of the horizontal volume
(TV) – centering on the horizontal fine adjustment (on TV) – centering
on a vertical,>-Select the sound standard Memory – ME (on TV) after
each adjustment. With the remote you can set the initial values ​​of
picture and sound settings, press the ME (on TV) – write to memory. Exit
– (POWER OFF).
BRAND Processors ST9093 ST92T93J9B1, chassis ICC9
  • With the remote turn the TV into standby mode.
  • Turn off the TV network switch.
  • By pressing the blue button (VT) enable the network switch.
  • Press the button again (VT).
BRAND, Chassis TX807
Push the purple button on the remote control and turn. Exit – (POWER OFF)
CIRTIS C-14/21/25/28M1/M2. Processor MC68HC705T10B
Close conclusions 13 and 23 of the SAA3010 in the RC.
CONTINENTAL CT1412. Processor ST6375
To enter the service menu to hold the button (+) (-) in front of the TV turn on the power switch
DAEWOO CHASSIS CP-375 Processor DW5255M2, DW5255RM.
All changes in service are made only through a special panel.
DAEWOO KR20V1T
Switch the TV on channel 91. Hide clarity to the minimum. On the remote
control to press the (red) (green) (menu). Exit – (POWER OFF).
DAEWOO DTC-14V1/V3/V4/V5/U1, DTC-20V1/V3/V4/V5/U1, DTC-21V1/V3/V4/U1/U3, Chassis CP-002
  • Select Channel 91
  • Set the sharpness to minimum
  • Exit Menu mode
  • Fast sequence of buttons to press RED – GREEN – MENU
You should see the inscription Service Mode OSD
Exit the service mode – Power off
  • Data Preset (D.P.) Adjustment
  • Select Channel 91
  • Fast sequence of buttons to press RED – GREEN – BLUE – MENU
  • You should see the inscription DP OSD
  • Channel Up, Down – choice
  • Volume Up, Down – Management
DAYTEK DCT-2062-S
On the keypad (DISPLAY) – (MUTE) – (SLEEP) – (FUZZY) further pressing
(DISPLAY) or (SLEEP) introduces a TV set in the service menu.
DUAL HANSEATIC SCHNEIDER M4055, ST6714, CTV2703. Processor CCU09 \ 10 \ 13. Chassis DTV-1
Pressed simultaneously (S) on TV and the button (C) on the remote control
DUAL HANSEATIC SCHNEIDER TV5504, TV5520, TV5525. Processor STV6385. Chassis TV-4
Press both the blue and red button on the remote control. Immediately press simultaneously (P +) and the (VOL +) on TV.
DUAL HANSEATIC SCHNEIDER TV1170, STV6156. Chassis DTV-2
Simultaneously press the button – the remote control (C), and the service button located on the bottom row console.
ELEKTA CTR-2145, DTV21F4 CPU LC863320A, videoprots. LA76810A
Log into the service mode: press a hidden button (PROD) on the remote control right of the Vol +
chip remote SC7461-103 (pins 2 and 15)
chip remote LC7461 (pins 2 and 16)
ERISSON S14, ERISSON 2120 or ERC 21NI60 chassis 3S10
Processor: ST92185BN4B1/PBI 3S10B-ENG/RUSS
videoprots.: STV2248C
Log-in service:
Menu – AV – ANAL
OK – a choice
PP – output
ERRISON 2102, 2103 Processor: S3P8849XZZ-AQB9
Close contacts 2 and 4 of the connector CN601. (ADJUST and GND)
Appears on the screen « KWTVA COMPUTER 11-23 »
Then click « OK » button on the remote.
Menu appears on the « KWTVA SERVICE 11-23 »
OPTION 5473176706
ERISSON S14 Processor: LC863324A, videoprots.: LA76810A
Log into the service mode: In the operating mode press the sequence on the remote: MENU – MENU-Q.VIEW – MUTE
OFF TIMER – regime change menu
MENU – write the new values
FINLUX 4028D. Processor SDA20160
Immediately after the TV issue the command from the console (PRG) (EXT). Exit – (POWER OFF).
FINLUX SERIA 5000. Processor SDA20320
Immediately after the TV issue the command from the remote (TV) (PRG) (EXT). Exit – (POWER OFF).
FINLUX 3021. CPU SDA2080
Click on the (N1) front panel TV and
quickly press the button which is located to the left of the button
(N3). Exit – click on the button located to the left of the button (N3).
FUNAI TV-2100A MK-7 MK-8
Close to each other 2 and 14 feet in
the RC circuit D6600A. Button 6 mode « PICTURE SELEKT » switch character –
a graphical display information OSD. It only works with an R-514
FUNAI TV-2100A MK10
To enter the service mode TV include the
operating mode and briefly join the free output resistor R137 to the
hull. Resistor located on a plateau near the control buttons.
In the corners of the screen appear the letters F. Choose the appropriate option button remote control:
1 – a horizontal line;
2 – AGC (AGC);
3 – VCO (HRA);
4 – H POSI (horizontal alignment);
5 – L-STER , H-STER [R], H-STER , L-STER [R] – color shades;
6 – point in the center of the screen;
7 – the illumination of the screen one of the primary colors;
8 – CUT OFF (black level RG B);
9 – DRIVE (increasing R, G, B);
0 – brightness, contrast, tint, NTSC, sharpness, saturation;
VOL + – Auto Search;
DISPLAY – adjust brightness, saturation and contrast. Definition;
SLEEP – Auto Search;
0/AV – cubyarkost, subnasyschennost, subkontrastnost, subchetkost;
PREVIOUS – AFT (AFT);
VR541 – vertical size.
VR542 – centering vertically.
Parameter value change buttons L CH V.
Adjusting the white balance to « white »:
• Press the button on the remote control 9;
• Press 1 to adjust the amplitude of R;
• Press the 2 button to adjust the amplitude B.
Adjusting the buttons L CH V.
Adjusting the white balance to « black »:
• Press the button 8
• Press 1 for adjusting the black level of R
• Press the 2 button to adjust the black level B
• Press the 3 button to adjust the black level of G
The parameters governing the buttons L CH V
Adjusting subyarkosti, saturation, contrast, sharpness, hue NTSC:
• pressing the 0 button several times, choosing the parameter;
• regulate the setting buttons L CH V.
To exit the service mode, press the button POWER.
Adjust settings are saved automatically.
Funai TV-2100A MK11 CPU LC863320A, videoprots. LA76810A
Log into the service mode: Close each pin. 2 and 16 RC
Valid for chips or remote SD7461GO RT2461-103
Funai TV-2100A MK12 Processor L11PAL 2ND M372CH8-056FP
In remote assembled on a chip 67N705 close third with the second (ground) terminal.
In the native RC is designated as the jumper J1. Login – SLEEP. Exit – STBY.
Work: Picture (bre, cnt, clr, tnt) VOL – switch other settings
buttons .. 2.3 6.8.9. At certain positions VOL – button work 1.2.3.
Adjusting the values ​​of buttons CH
GRAETZ
Turn the switch to digital module ‘TV Internal Service Program’ (SE on display).
GRUNDIG M63-105 ST63-160, ST63-781, E63-911. Processor MC68HC11F1. Chassis CUC1822/1823/1852
Starting
processor (contact MP2) and turn on the TV to the network. Click (i) on
the remote control (TP760). With the help of (P +) and (P) to select
SERVICE. Press (OK), enter the code ( (5) (0) (0)
GRUNDIG ST82775, ST95775, Processor SC415008FN4. Chassis CUC7880/7890
Push (i) will INFO CENTER. SPECIAL FUNCTION to select and click OK. Enter the code ( (5) (0) (0).
GRUNDIG M55-.., M63-.., ST63-.., ST70-.. Processor SDA2056/20562. Chassis CUC5360/5361/5510/551.
Click on the button (P / C) on the remote control to include a network switch. Exit – POWER OFF.
GRUNDIG ST55-725 ST55-750 ST55-800 ST55-95. Processor ZC411867P (MC68HC05T3). Chassis CUC2075, CUC7350.
GRUNDIG P37 .. P40 .. P42 .. P45 .. P50 .. T5 .. T55 .. Processor ZC88642P/88644P/42470. Chassis CUC6300.
GRUNDIG BOSTON ST270/8/IDTV/LOG. Chassis CUC1825, CUC1826.
Press the key (i) on the TV and click (OK) on the remote. Remember the value of (QA).
GRUNDIG GV200VPS. Processor SDA2087N.
On the remote press (CODE), then (4) (9) (3) (4). Confirm (OK) and press (STANDBY).
GRUNDIG M70-100, M70-580, M82-100, M95-100, M70-681. Processor SDA30161. Chassis CUC1835, CUC1860, CUC1880, CUC1890
Click
(i) on the remote. Use the (P) to cause the regime SERVICE DEMO press
(OK) (AUX). Call SERVICE MODE (OK) ( (5) (0) (0). Unlock: (VIDEOTEXT)
(PAGE) (CANSEL) (PAGE) (OK). Something to remember adjustment in service
mode to 7yu SDA3526 foot planted on the ground.
GRUNDIG M70-290 / 9 M84-211 / 8. CPU SDA5250-100. Chassis CUC1836, CUC1929.
Click
(i) on the remote. Use the (P) to cause the regime to press DIALOG
CENTER (OC). Call For authories dealer (OK) ( (5) (0) (0). Exit –
POWER OFF.
GRUNDIG P37/40/50 T51/55/65. Chassis CUC5301
Close legs processor RC MC144105 findings 6 and 10.
GRUNDIG P37-065/070/730. Processor ZC88667P ZC411718P SDA5222. Chassis CUC7300, CUC7301, CUC7303
GOLDSTAR CF-25 \ 29C44 chassis MC-51A
Click the OK button for a long time on the board Control board and the yellow button on the remote.
GOLDSTAR CF-25, CF-29, C26, C36, C76 chassis MC-51B
Simultaneously
press (MENU) (- VOL) ​​(- PR) Panel (OK)-store changes. To go to the
adjustment of white: = i – for GGB =? – For RGb = h – for BG.
Choose
option buttons L (CH) V. Change the value of buttons + (VOL) -.
Parameters recorded in the memory is automatically output – POWER OFF
GOLDSTAR Model CTK-4745. Programming produced by domestic remote PC-4
GOLDSTAR Model CB25C20X Processor GS831001A (SDA20160) Chassis
PC33B. Log in with a special remote control. Press and hold (SVC).
Console is built on a chip SAA3010. Close pins 1 and 11
HITACHI CP2893TAN, CL2995TAN, CL28500TAN. Processor M37270MF. Chassis A5WK.
Hold down the button on TV (VOL +) and (VOL-) and turn the power switch. POWER OFF.
HITACHI CS2840TA. Processor NES3-…, NES2-… Chassis EUROSTE REO-2
(-/–) (MENU) (TV) – 1 sec. Exit – POWER OFF.
HITACHI C25 \ 28P445VT, C21 \ 1925 \ 28P745VT, C28P405VT. Processor CCU-SALO-09 (CCU20XX). Chassis DIGIT2000.
(P) (*) (O / V) (#) (M). Exit – (TV).
HITACHI 43FDX, 53FDX.
Open the front panel (four screws, two on each side). Remove the center
panel (six screws). Press the blue button in the left corner of the
board set. Exit – Press the blue button again
HITACHI C2578FS, C2589FS, CMT2578. Chassis V1
At the front of the TV, press (TV \ AV) and holding it turn on the TV.
After completing all adjustments, press the ENTER button on the remote
control (remembering), then the MENU button or turn the TV off.
HITACHI C2135MN
Turn on the TV’s front panel while holding the (-) button.
HITACHI C2160FS Z90234-4481 processor, videoprots. TDA8842
Log-in service: turn on the TV power switch holding the TV \ VIDEO on the front.
ITT 359, 387, 8F HIFI, CB5373Z, 6578F. Processor CCU SEL04/SEL07A
Mode 1: Press the screwdriver, the contact in the hole about the keypad and press the right button (S)
Mode 2: Press the screwdriver, the contact in the hole about the keypad
and press the right button (S) and re-click on the contact. Exit –
(LOAD).
ITT Processors: SAA1293-03-03 SAA1293A
On the keypad on the TV horizon without graphics click « SERVICE », the indicator will show
CH, press it paz – there will be OP, on volume select number of registers
(1-4) and figures (1-9) to change bits. After you press the ‘Memory’. (You can also close the
conclusions of 15 and 23 SAA1250 chip in the console). Exit – POWER OFF.
JVC AV-29PRO
Set the volume control 04, and then successively press on the remote (DISPLAY) (MENU).
JVC C-21ZE, AV-G140T, AV-210T, AV-14ME, AV-14TE, AV-21TE/TE, AVG21T, AV-G250MX, 21A4EE, 21F4EE. Chassis MZ2, CA2
Simultaneously press the Control (DISPLAY) and (PICTURE MODE). (OFF TIMER) – remember.
Processors: M37102M8-C41SP. Menu is displayed as in Figure 1.
1. VCM PRESET change the preset brightness contrast and clarity.
2. SUB VSM switching color standards.
3. IF V \ C to change the settings correct screen mode and RGB matrices.
Next, you must again press the key combination and DISPLAY PICTURE MODE to display
screen system constants. The screen image will appear as in Figure 2.
Key PICTUPE ADJUST selects the position and the key PICTUPE ADJUST + / – changes
value. For storing settings, click the button OFF TIMER. To return
to the normal screen twice, press MUTE.
JVC A32020
Set (SLEEP TIMER) to 0 MIN, and so far is displayed on-screen information, press (DISPLAY) + (AV)
JVC AV-29TH3ER
On the remote control at the same time (MUTE) and (INFORMATION).
JVC AV-25TS2EK. Processor M37204MCC40SP. Chassis JE.
(I) (MUTE). Exit – (TV).
JVC AV-25VM1EN, AV-28VM1EN. Chassis JC.
DISPLAY) (CINEMA / GAME). Exit – (DISPLAY).
LG MC64, MC84, SF-20/21, F60, CF-20/21, F80, CF-14/20/21, K40E, CF-14/20/21 K50/E/X, CF-14/20 / 21 K52E / X,
CF-14/16/20/21 S10EX, CF-14/16/20/21 S12E
Chassis – MC64, MC84, MC84A.
Log into the service menu: Simultaneously press OK on the remote control and on the TV.
LG KF-14/20V30, KF-14/20/21U30/40, TVCR-060898 Use a regular
remote control, if removed from his upper lid, then you will see 4
groups of contacts for the 4 buttons, but not in the top cover under
these buttons holes and keys. Second from the left button is used to
enter the service mode.
LORENZ. Models: 359, 387, 8F, HIFI, CB5373Z, 6578F. Processor CCU SEL04/SEL07A.
(LOAD)
LORENZ. Processors: SAA1293-2003, SAA1293A-03.
C remote from TV « Horizon » without graphics click « SERVICE »,
indekatore displayed on CH, Press again – there will be OP, on volume
choose the number of registers (1-4) and figures (1-9) to change bits. After the press
« Memory » (you can just close the conclusions of 15 and 23 IC SAA1250
in the control) Exit – POWER OFF
LIFETEC Model LT7000, STV6708, CTV2781. Processor ST6365.
Simultaneously pressing the red and blue buttons on the remote control.
Immediately thereafter, simultaneously press the (P-) and (VOL-). Exit –
(TV)
LOEWE. Model, ART500, ART630, ART700. Chassis – C9002S.
Hold the button (SERVICE) on the TV press on the remote control (CM). Exit – (TV)
LOEWE. Model 9000. Processor CUC2070. Chassis – DIGIT2000.
Press the service button on the motherboard around the CPU (pins 22 and 39) and click (CM) on the remote.
LOEWE. Model 7000. Chassis – S9003.
Five times to press the cursor right on the TV and just press the button (MEN) on the remote.
LOEWE . Chassis – Q2200.
Select ‘SERVICE’ in the menu, and then quickly press the ‘MENU’ button
on the remote. Choice: the yellow cells. Setting: + / -. Remembering:
‘X’. Output: ‘TV’.
LUXOR 5585-21A1, 7057-27, 63/7954 Chassis – « STEREO PLUS ».
Log in Service: MUTE -> OK (M) -> TV Remember: OK (M). Exit: TV.
MITSUBISHI CT-21M5E \ ET \ RT, CT-25M5E \ EN \ ET \ ETN \ RT \ RTN:
Login: Hazhat on sepvisny pepeklyuchatel S701 (Close to tyunepom), then knopky 9 (in the limits of 5s).
« * » – Pepeklyuchenie pegylipovochnogo monitor displays, « 2 » – 8 « – pegylipovka code » 6 « – » 4 « – pegylipovka data » 0 « –
write to the memory, « 1 » Undo changes to records in memory. Output:
stand by. Button TV / AV – Exit from those. menu.
TUN 1 (0) – bands UHF, VHF
HTL 1 (0) – Disable the button « INSTALL »
TXT 0 (1,2) – 1 – Teletext incl. 2 – off
MNP – press « * » – entry in the settings menu
AVI 0 (1,2) – inputs AV: 1,2 – is
SYS 0 (1,2,3) – standard color (it should be SYS 1 or SYS 2)
STD 0 (1,2,3,4,5) – Standard audio (must STD 3)
MITSUBISI CT-29B3EEST
Turn on the power. Small screwdriver, press on the micro switch S701, located
next to the slot antenna. And then on the remote 9 button for 5 seconds. Record
– Button 4. Buttons 2 and 0 to change the code control buttons 5 and 7, change the value
data.
MITSUBISHI Model: CT-29B3EEST, CT-29B2EEST, CT-21M5E/ET/RT, CT-25M5E, CT-25M5G.
Processors: CXP80424, ST9291N6B1NO/B10, ST9291N6B1ECS/B20.
Chassis: EURO-11, EE-3, EE-4
Powering up. A small screwdriver to press the mikrik S701, located near
with an antenna jack, and then – on the remote button « 9 » for 5 seconds.
Exit – (CM) POWER OFF
MAGNAVOX. Chassis – SOME.
To access the menu with the remote, press the following combination (0), (6), (2), (5), (9), (6). The channels are
change. Then press (MENU). To save your changes, press POWER on the TV.
MEDION SEG. Stamps – CT8050, CT8100, MD7103. Chassis – 11AK18.
Log into the service mode by pressing (MENU) + (1) + (6) + (7) + (5). Exit – (MENU
NOKIA 6364, 7364 CHASSIS 2B-F:
Click on the button to turn the console – \ – -> MENU -> TV last button hold
within 1 second. Output from the service button to turn off the console.
NOKIA, SELECO, SABBA ITT, TELEFUNKEN (Chassis
STEREO PLUS)
Input: 1. (Mute); 2. (OK); 3. (Tv); record pezyltata « OK »
Exit: TV
NOKIA Model SAT1700.
(STORE ),(-/–),( TV / SAT)
NOKIA Model 8003.
(OK), (MUTE), (TV / SAT)
NOKIA Model: 3725CW, 4525CW, 5125CW. Processor – ST6367.
Pushing quickly (MUTE) (OK) (TV). Output – TV
NOKIA Models 61971, 6197, 6197DPL, 7282, 7295, 7296, 8296. Processor – SDA30C163.
Turn on the TV power switch in the lodge for 5 seconds command with the remote control (MENU) (TV) (i).
Exit from the menu – POWER OFF
NOKIA. Models: 6384, 6394, 7184, 7194. Processor CCU3000. Chassis – EURODIGI.
Initialize memory: Turn on the TV and just type a command from the control (MUTE) (TV).
Exit – POWER OFF
ORION 28BDF TV790 Processor SAA 5297PS/262.
Turn on the power button while holding down the MENU button on the front
panel, until the LED. Next, turn to the STBY button remote control.
Yield: menu OFF
ORION TV2180MK6 Processor OEC6027A (TMP87CH37N3194-9901H)
At the front of the TV, press and hold down the « VOLUME < » to « 0 », then hold, press the remote button « 9 ».
The service menu consists of two sub-menus.
  • First:
    1. CUT OFF
    2. AGC
    3. V. SIZE
    4. BRIGHT
    5. COLOUR
    6. TINT
    7. END
  • Second:
    1. AUTO
    2. SUB BRIGHT AUTO
    3. VCO AUTO
    4. AFT AUTO
    5. VCO
    6. AFT
    7. CONTRAST
    8. END
    Selecting items in the submenu by pressing the appropriate « license »
    keys on the keypad. Adjustment parameters are the keys « VOL  »
    or « – SET + » button on the RC.
    The yield of the items in a submenu, as well as the transition from one
    submenu to another made the same combination: « VOLUME < » to « 0 »,
    holding it press on the remote control key « 9 ».
    All values ​​are stored automatically.
    Exit the service menu is by selecting « 8 » in any menu or by pressing the
    « POWER ».
    ORION T2157/67/97, ​​T2567/97, ​​T2967/97 CPU LC863328A (5W63)
    1. In the « STAND BY » press « RECALL » button on the RC
    2. Pressing the « VOLUME < » on the front of TV set the volume level to « 0 »
    3. Hold down the « VOLUME <« , repeatedly press the « RECALL » button on the RC
    Note: At default, paragraph 1 – the entrance to service the fifth attempt
    The service menu is composed of four sub-menus:
    • FACTORY (training)
    • B / W (WB)
    • ADJUST (control)
    • SETUP (setup system constants)
    Selecting a submenu by pressing the « RECALL » on the remote.
    Note: At default, paragraph 1 – to select the fifth menu by pressing the « RECALL » button on the RC
    Access to adjusting the parameters of the keys « VOLUME « .
    Selection and adjustment of parameters, the keys « P + / P – » and « VOLUME
    Exit the service menu – pressing the « POWER
    PANASONIC TX-29GF35T, TX-33GF85T, TX-29GF85T chassis M18
    Optional test is included if you press both
    OFF TIMER button on the remote button and VOLUME-(minus) on the front of the TV.
    Setting memory chips after e | replacement. Jumper TRA4 (contact
    3 IC1213) and the TV (by mass). Then turn on the TV’s power.
    Apparatus clicking | m mode Market Mode. After the operation the jumper should be removed.
    PANASONIC TC-24WG12H, TC-28WG12H GAOO Chassis M17W
    Optional test is included if you press the button simultaneously OFF TIMER
    button on the remote and VOLUME-(minus) on the front of the TV. Configuring Products
    memory after e | replacement. Jumper TRA14 (pin 3 IC1213) and the body
    TV (mass). Then turn on the TV’s power. Apparatus clicking | m mode
    PANASONIC TC-21E1R To enter the service
    mode you must click on the main board of TV service button S1101.
    Appears SNK. After the first nahatiya can adjust the basic (control
    Brightness, Contrast, saturation, volume and phase (horizontal alignment)).
    A second press of the button allows you to adjust modes tsvitnost RGB. FUNC –
    change of the controlled object, NORM output.
    PANASONIC TC-29V50R CHASSIS MX-2A
    Tuning mode: Press the service switch S1101 (located near
    alignment with the switch) TV switches to check on the screen
    appears SNK. Click S1103 (FUN) to select the desired adjustment,
    To exit, press S1101.
    PANASONIC TC14S1RCP, TX14S1TCC, TC21S1RCP, TX21S1TCC, TX21S1TCP CHASSIS Z5
    This chassis has the ability to self-test. To call the regime of self-testing
    need to press buttons simultaneously OFF Timer button on the remote and VOL (-) on
    the TV. After which the TV will go down in the process of self-testing and
    will give on-screen message which is shown in Figure 1
    What is the significance of these data. 1 (+) test EEROM (IC1205) plus indicates that
    okay, 2 (+) Verify the microprocessor teletext, 3 (+) Check the tuner.
    Attention TV model without teletext show option 2 (-).
    Next, you need to make the installation options.
    1.Set color saturation and sharpness to the minimum
    2. Press the OFF Timer button on the remote control and the F key on the TV. Will
    picture as in Figure 2
    3. Select the desired option UP / DOWN keys on the remote.
    4. Select the decimal value of the buttons 0-7.
    5. Click on STR to store the changes.
    6. To exit the TEST mode, press F.
    PANASONIC CHASSIS MX3, MX-3C
    Simultaneously press the RECALL button on the remote and-VOL on the TV. Output 2 times click on
    remote button NORMAL.
    PANASONIC TX-21AD2C, TX-29A3C, TX-25A3C CHASSIS EURO-2, EURO-1
    Set the BASS control of the lower audio frequencies at a maximum, TREBLE knob treble
    at a minimum. Press F on the TV at the same time with a button REVEAL
    on the remote.
    PANASONIC GAOO70 TX2170T
    To enter the service menu you must click on the television V-(volume down) and hold
    it pressed click the button on the remote which izabrazhen ekranchik plus. For
    exit the menu should go to the submenu. Tam in the upper right corner is written in yellow and CHK nazhat N.
    PHILIPS 14PT-1342 / 43, 14PT-1352 \ 00 \ 01 \ 05 \ 07 \ 11 \ 39
    14PT-1542 \ 01 \ 43, 14PT-1552 \ 00 \ 01 \ 05 \ 11, 20PT-1342 / 43, 20PT-1542 / 43, 21PT-1532 \ 58,
    21PT-1542 \ 43, 37TA-1232 \ 03, 37TA1432 \ 03, 37TA1462 \ 18, 37TA1473 \ 18, 52TB-2452 \ 19,
    M-2052 \ 00 \ 01, M2152 \ 00 \ 07 \ 15, M2182 \ 00, M2192 \ 05 CHASSIS L6, 1 AA
    There are 2 ways to enter the service.
    1.Zakorotit contacts S1 S2 on the processor (pin 14 IC7600)
    2.C using the service console model RC7150 pressing the mute button DEFAULT or ALIGN.
    Output from the service click on the button STAN-BY.
    PHILIPS 25PT8303
    Log odnovpemenno press « ? » and « sleep » under kpyshkoy.
    PHILIPS Anubis S \ DD.
    Log in to the service mode by contact closure, M31 and M32 (land) near IC7710. Exit STAN-BY.
    PHILIPS 14PT-118A \ 50B \ 67R \ 94R, 14PT132A \ 50B \ 50R \ 75R,
    14PT133A \ 162R, 14PT137A \ 162R, 14PT138A \ 54R \ 58T \ 67R \ 71R \ 74R \ 75R \ 93S, 20PT188A \ 50B \ 67R \ 73R,
    20PT120A \ 78R, 20PT132A \ 75R, 20PT137A \ 62R, 20PT138A \ 50D \ 58R \ 58H \ 58R \ 67R \ 71R \ 73R \ 74R \ 75R \ 94R \ 97R.
    CHASSIS L7, 1A \ AA
    Short-circuit contacts M24 and M25 on the circuit board (PCB). Output from the service click on the button STAN-BY.
    Attention buffer error is cleared!
    PHILIPS 21PT440B, 21PT441B/02B, 21PT442B, 21PT4303,
    21PT4422, 24PW6302, 24PW6322, 25PT5403, 25PT45, 25PT4523, 25PT5302, 25PT5322,
    25PT5403, 25PT5423, 25PT6322, 25PT4503, 52TA4311. CHASSIS MD1.2/AA /
    Processors
    TMP87CM36, TMP87CM38N
    To enter the service mode is used panel type RC7150. With this panel TV can be translated
    in two modes. 1 service is the default mode SDM (button DEFAULT). In regime
    default, you can also enter through the contact closure S42 S43 on SSP (Panel
    Small signal). To exit, press the button (Stand-by) (buffer error
    cleared). 2 service adjustment mode SAM. Log in SAM mode is carried out
    by sending commands ALING simultaneous pressing (MENU) and (-). After
    enter the menu you will see a picture like Figure 1.
    To exit, use the button (Stand-by) for errors can be monitored by
    LEDs on the front of the TV. The list of error codes in the table.
    Error CodeError DescriptionCount – in the blinkFaulty component
    0 No Error ——— ———————-
    1 Error BIMOS (TDA8366) 1 IC7119 (SSP)
    2 Error MSP3400/3410 2 IC7353 (SSP)
    3 I2C bus error 3 All components on the I2C bus
    4 Not the Rom (EEROM) 4 IC7685 (SSP)
    5 Defective ROM (EEROM) 5 IC7685 (SSP)
    6 Error Tuner 6 U1000 (SSP)
    7 Error Teletext TXT 7 IC7702 (SSP)
    8 CPU error Histogram 8 IC7210 (reserve)
    9 CPU error 16:9 9 IC7440 (module 16:9)
    10 Error module WSSB 10 IC7540 (module WSSB)
    11 Error processing Dolby 11 IC7600 (audio module)
    PHILIPS 25PT400/42, 25PT410A/42, 28PT400A/42, 28PT450A/42 CHASSIS GR2.2AA. Processor TMP47C1637
    Log in servistny mode as follows. Zamyknite contacts M33 and M34 (service), and pressing
    INSTALL on letsivoy panel enable the network pareklyuchatel. The screen should appear
    Post SER. To exit the service please click on the button STANDBY.
    Also in these models is servistnoe menu. Activated by pressing
    VOL +, and then ETOGES time by pressing P +. In the second variant values
    stored immediately. Go to the hotel mode as follows.
    Turn on the TV for 38 channel while nazhamite keys VOL-, P-front
    the TV.
    PACE PRIMA Model: MSS100, MSS200, MSS500
    Log into the service menu – (MENU), (0), (STORE), (RIGHT ANOW), (LEFT ANOW)
    PRINCETON Model – AR2.7T
    Log in – holding the button (+ VOL) ​​switch on / off switch
    PROELCO Models: TAP2131, TAP2531, TAP2831 Processor 82C52.
    Close the control points TR501. Hold (R +) (P) include
    power switch.
    Exit from the menu – remove the jumper TR501.
    PROELCO processor-based SDA20563-A508/A516/A518.
    Close the output processor 21 to ground. Click on the TV (P +) and (P) and include a network switch.
    Exit – POWER OFF
    PROSONIC Model CTV7289DVT Processor – SAA5296. Chassis – 11AK16
    Log – (MENU) (3) (2) (9) (7)
    Exit – (TV
    SABA Model – 21MG77C Processor – ST9291 Chassis – TX-90, TX-91, TX-92
    1. On the keypad press (STAND BY)
    2. Turn off the TV power switch
    3. Hold the button on the remote control teletext (blue) – turn the power switch.
    4. After turning on the TV, let teletext.
    5. If you do not work, then in paragraph 4 of the button and release again quickly, briefly press.
    6. Output from the service – POWER OFF
    SABA Models: 28DT178ME, 28WS78KE/M/MP, 28DH78K, 28DU78K,
    28DU88M/NE, 28DU98MP, 32VT88NP, 37WS88ME
    . Chassis – ICC19.
    To access the menu to hold down the button (PR-) and (VOL-) on the front panel
    TV turn on the power switch.
    SABA Models: 52RW64E, 44W65ES, 52RW65ES, 52RW77WS
    Turn on the TV while holding the button (PROG-) and (VOL-)
    SABA processor ST9093. Chassis – ICC9.
    Turn on the TV holding the blue button on the remote. Hold 5 seconds. Exit – POWER OFF
    SABA Processor ST90R91 Chassis – ICC10
    Method 1: Turn on the TV holding the blue button on the remote for 5 seconds.
    Method 2: Turn on the TV holding the button (PROG-) and (VOL-). Hold button
    8 sec.
    SALORA 6390, 7190, MV4000, PL14, 24101 852 SAT SOLI, 882 SAT SOLI, 885 SAT SOLI processor CCU-SALO-07 (CCU20XX), M1 chassis
    (C) (*) (O / V) (#) (M), Output – (!)
    SALORA 5575SFN, 28T7, processor ST92T93, chassis STEREO PLUS
    (I) (M) (P)
    Exit – (TV)
    SALORA DIGIVISION 63 .. 2 71 .. 2, 2, .. N6 Processor NES3-… NES2-.., chassis EUROSTE REO-1
    SALORA Processors TVPO2065-DO1, TVPO2066-A24
    Close contacts 15 and 23 SAA1250 in remote or close contacts 14 and 19
    in the SAA1250 RC. If not immediately included in the menu, you will
    need an additional close contacts 11 and 21 in the SAA1250 RC.
    Exit – (AV)
    SAMSUNG(Candy bar) CHASSIS: SCV11A, B Model TVP3350, TVP5050, TVP5350
    Login: StandBy -> P. Std -> Menu -> Sleep -> Power On
    After logging into the service mode the on-screen menu appears: Adjustment, Option byte, Reset.
    Abbreviations used in the mode of Adjustment: AGC – Auto Gain Control, SBT –
    Sub Bright, SCT – Sub Contrast, SCR – Sub Color, STT – Sub Tint, PDL – Pal Delay,
    NDL – NTSC Delay, RC – Red Cutoff, GC – Green, Cutoff, BC – Blue Cutoff, RG
    – Red-Green drive gain, BG – Blue-Green drive gain, PSL – PAL vertical SLope,
    PVS – PAL Vertical Shift, PVA – PAL Vertical Amplitude, PHS – PAL Horizontal
    Shift, NSL – NTSC vertical SLope, NVS – NTSC Vertical Shift, NVA – NTSC Vertical
    Amplitude, NHS – NTSC Horizontal Shift.
    OPTION
    BIT ITEM 0 1
    7
    TTX
    NO TTX
    TTX
    6
    TTX SYSTEM
    LIST FIRST
    FLOF FIRST
    5
    CONTRAST
    90
    100
    4
    TUNER QUANTTITY
    1
    2
    3
    TUNER KINDS
    2889
    0889
    2
    SYSTEM (L)
    1
    SYSTEM (D / K)
    0
    SYSTEM (I)
    OPTION 2
    BIT ITEM 0 1
    7
    NOT USED
    6
    NOT USED
    5
    POWER ON AFT
    ONCE
    TWICE
    4
    PDC
    NO
    YES
    3
    VPS
    NO
    YES
    2
    3.58 X-TAL
    NO
    YES
    1
    VIDEO PLUS
    NO
    YES
    0
    SHOWVIEW
    NO
    YES
    VCR OPTION
    BIT ITEM 0 1
    7
    NOT USED
    6
    NOT USED
    5
    NOT USED
    4
    HEAD
    2-HEAD
    4-HEAD
    3
    SP / LP
    SP-ONLY
    SP / LP
    2
    SECAM
    N / A
    POSSIBLE
    1
    MESECAM
    N / A
    POSSIBLE
    0
    NTSC3.58
    N / A
    POSSIBLE
    SAMSUNG CK5038 ZR \ TBWCX CHASSIS SCT11B
    Press the following sequence of buttons on the remote: STAND-BY -> P. STD
    -> HELP -> SLEEP -> POWER ON.
    Exit from I STATUS.
    Under the panel
    console is a hidden button HIDDEN using this button, you can enter and
    exit the menu.
    SAMSUNG CS7272 PTR \ BWX CHASSIS SCT 51A
    Enter the menu allows the following sequence of commands: PICTURE OFF ->
    SLEEP -> P. STD -> MUTE -> PICTURE ON.
    SAMSUNG CK6202 CK7202 CHASSIS SCT12B
    Exit button or HIDDEN STATUS.
    SAMSUNG CS-721, CS-723 CHASSIS SCT-52A
    Alternately, press the button on the remote PICTURE OFF -> SLEEP -> P. STD -> MUTE -> PICTURE ON. Movement
    cursor keys CHANNEL and VOLUME.
    SAMSUNG CK 6271 WP
    menu to 1. Hazhat button (HIDDEN) – hidden on the remote control 2. Hazhat very
    rapid follow-up. (Stand-by) 3. (P.std) 4. (Help) 5. (Sleep) 6. (Power-on)
    SAMSUNG CS 2139TR, CS21A0QWT, CK-564BVR, CZ-21H12T, CS-25M6HNQ, CS-21S4WR, CS-21S1S, CS-21D9 Chassis KS1A
    (STAND-BY) (DISPLAY) (MENU) (MUTE) (POWER ON)
    SAMSUNG CS-29A6HTR PLANO
    (STAND BY) (DISPLAY) (P. STD) (MUTE) (POWER ON)
    SANYO C21ML1 (MG) Processor: VESTEL 19V1.0NT
    The entrance to the service. Push MENU (INSTALL), put cursor on « Configure ».
    SONOLOR Models: 5552, 6352, 6363, 6372, 6383, 7163, 7172, 7183, 63SN601. Processor NES3AR01/02, NES2-2R01/4R01
    Login: (-/–) (MENU) (TV) – a combination of all the press for 1 second.
    SONY KV-S2171K, KV-C2171KR, KV-X2101K, KV-X2501K, KV-X2581K, KV-X2581KR, KV-M2540K, KV-M2541K, KV-X2901K, KV-X2981K, KV-X2981KR Chassis BE-3B
    In standby mode for up to 20 seconds on the remote control RM833 Repeatedly
    Button: (Display on screen) (5) (VOL +) (TV). In the upper right corner will
    inscription TT -.
    SONY KV-M1440, KV-M2170, KV-M2171, KV-M2181, KV-M2101
    Set the TV to standby mode. Next, you need to press a remote button in a sequence of ON SCREEN DISPLAY ->
    5 -> VOLUME + -> TV. Data are given for the console type RM-836.
    The number of flashes the LED Value error
    2
    IC301ne confirms the transfer of 12C-volatile memory in order
    3
    IC301neispravna flags.
    4
    No flyback horizontally.
    5
    IC301perepolnenie stack.
    6
    Fired Over Voltage Protection / current (pin 52)-high (1).
    7
    IC002ne confirms the transfer of I2C, IC301-right
    8
    IC002i IC301-no confirmation I2C.
    9
    Total oschibka I2C (SDAi SCLna low (0) IC301, IC001, IC002, CN001).
    SONY KV-24WS1A/B/D/E/K/R/U CHASSIS BE-3B CXP85340A-116Q/117Q RM-837
    Set the TV to standby mode. Next, you need to press a remote button in the sequence
    ON SCREEN DISPLAY -> 5 -> VOLUME + -> TV.
    Number of outbreaks
    LEDs
    IC Type
    Fatal error if
    2….9 NVM (EEROM) YES
    10 TELETEXT ©
    11 RGB / JUNGLE YES
    12 Switch AV TV. ©
    13 PLLtyunera YES
    SONY KV-24WS2A/B/D/E/K/R/U CHASSIS BE-3D MSP3410B-PS-F7-T, MSP3410C-PS-C6-T RM-862
    SONY KV25C1/A/D/B/E/R/K, KV29C1/A/B/D/C/K/R/E/D1 CHASSIS BE-3D RM-839
    Set the TV to standby mode. Next, you need to press a remote button in a sequence of ON SCREEN DISPLAY -> 5 -> VOLUME +
    -> TV.
    SONY KV-2170, KV2180, KV2540 CHASSIS BE4
    Set the TV into standby mode and press the button on the remote in the next
    sequence ON SCREEN DISPLAY -> 5 -> VOLUME + -> TV.
    Exit 00.
    SONY KV2181KR SHASSIS BE-4
    ON SCREEN DISPLAY -> 5 -> VOLUME + -> TV. Data are given for the console type RM-836.
    Number outbreaks LEDs Value Error
    2
    3
    4
    5
    6
    7
    8
    9
    SONY KV-E2551A \ B \ E \ K, KV-S29 JN1 \ MN1 \ SN1, KV-S34 JN1 \ MN1 \ SN1 CHASSIS AE-2B
    Use the remote type RM-831. Turn on the TV while pressing the button on any 2
    front of the TV.
    Type Products Functional appointment
    1 I2C bus At SDAnizky level (0).
    3 SDA3202 Tuner (PLL).
    4 TDA9145 Chroma decoder.
    5 CXA1587 RGB / Jungle.
    6 TDA6612 Sound processor.
    7 CXD2018Q Scan vertically.
    8 CXA1545 Switch AV / TV.
    9 © Protect scan vertically.
    SONY KR-S4613 SHASSIS AP-2
    Use the remote type RM-832. Turn on the TV while pressing any 2
    button on the front of the TV.
    Number outbreaks LEDs Type Products Functional appointment
    1 I2C bus Low level at SDA
    2 X24C16 EEROM
    3 SDA3202 PLLtyunera
    5 CXA1587S RGB / JUNGLE
    7 CXD2018 Vertical Scan
    8 CXA1545 Switch AV TV.
    11 SDA5248 Teletext.
    13 © Sewn vertical sweep.
    SONY KV-B2911/A/D/B/K, KV-B2912V, KV-B2913E CHASSIS AE-2
    Use the remote type RM-830. Turn on the TV while pressing any 2 buttons on the front
    the TV. In the upper right corner of the screen appears TT. After
    then press MENU. Error can be opredilit the number of LED flashes
    on the front of the TV. Process called self-diagnosis.
    2 X24C16 EEROM
    SONY KV-T25MF1
    Install the TV in standby mode with the remote then enter the following commands DISPLAY
    -> 5 -> VOLUME + -> POWER. The sequence of operations in the mode of SERVIS
    follows. 1i4 movement by position, 3i6 increasing and decreasing values
    MUTING write 0 performance record. Applied remote RM-870
    SONY KV-M2540
    Set the TV into standby mode and press the button on the remote control in sequence ON
    SCREEN DISPLAY -> 5 -> VOLUME + -> TV. Applied remote model RM-833
    SONY KV-S29 RN1 \ 34RN1 SHASSIS G1
    Entry into service mode by using the remote control RM-821. Turn on the TV in
    standby mode. Then press the following combination of buttons on the remote: DISPLAY ->
    5 -> VOL + -> POWER
    SONY KV-S2941A \ B \ D \ K, KV-S2942U, KV-S2943E SHASSIS AE-2F RM-831
    Turn on the TV, and then double-click on the button on to do. In the upper right corner appears on the TT, then press
    click on MENU.
    2 X24C16 EEROM
    2 X24C16 EEROM
    SONY KV-29X1A \ B \ D \ E \ K \ L \ R \ U CHASSIS BE-3D
    sequence ON SCREEN DISPLAY -> 5 -> VOLUME + -> TV. Applied
    Remote model RM-839.
    Error
    Protection circuit 2
    Low signal SLCna I2C bus 3
    Low signal SDAna I2C bus 4
    Low signal SLCi SDA 5
    Kontreller JUNGLE / CHROMAne answers 6
    Video switch is not responding 7
    Tuner does not respond 8
    MSPne answers 9
    NVMne answers 10
    Low signal M3L TXD 11
    Low signal M3L RDX 12
    Low signal M3L ENABLE 13
    Low signal M3L TXD and RXD 14
    Damage to test Compact Text 15
    Switch AVne reset when power is turned 16
    Unable to initialize the jungle 17
    Reply NVMpovrezhden after initialization 18
    A few chips do not meet 19
    Wrong time of the Compact Text 20
    Response switch AVpovrezhden after answering 21
    Reply controller JUNGLE / CHROMApovrezhden after the response 22
    Compact Textne answers 23
    SONY KV-29X1A \ B \ D \ E \ K \ L \ R \ U CHASSIS BE-5
    on the remote control in sequence ON SCREEN DISPLAY -> 5 -> VOLUME +
    -> TV. Applied remote model RM-836.
    The number of flashes the LED Value Error
    2
    memory-to-right
    3
    4
    5
    6
    Fired Over Voltage Protection / current (pin 52) high-
    level (1).
    7
    8
    9
    IC002, CN001).
    SONY KV-S2951 KR CHASSIS AE-3
    – And + on the front of the TV.
    Number – in Meghann LEDs Description Fee
    1 Common error I2C Bus –
    2 Error IC ST24C16 A
    3 Error sub-controller CXP85332 A
    4 Error video processor CXD2030R B B 1
    5 Failed to digital converter sampling CXD2032R B B 1
    6 Error converter review CXD2035R B B 1
    7 Error video controller TDA1839 A
    8 Driver error CRT TDA1840 A
    9 Failed to switch AV TV CXA1855 J
    11 Error chip Megatext CDA5273 A
    12 CPU error sound TDA6812 A
    16 V-protectionzaschita voltage –
    SONY KV-16WT1 A \ K \ R \ U
    Set the TV into standby mode and press the button on the remote in the following sequence
    ON SCREEN DISPLAY -> 5 -> VOLUME + -> TV. Applied remote model RM-836.
    2
    3
    4
    5
    6
    7
    8
    9
    SONY KV-C2173 B / E, KV-C2171 D / K / KR CHASSIS BE-3B:
    Remote model RM-833.
    Number outbreaks
    LEDs
    Type Products
    Fatal whether error
    10 TELETEXT ©
    11 RGB / JUNGLE YES
    12 Switch AV TV. ©
    13 PLLtyunera YES
    SONY KV-2501 A / D / K, KV-C2503 B / E, KV-C2508 D / E, KV-C2509 B / D / E / K.
    -> TV. Applied remote model RM-833.
    Number outbreaks
    LEDs
    Type Products
    Fatal whether error
    10 TELETEXT ©
    11 RGB / JUNGLE YES
    12 Switch AV TV. ©
    13 PLLtyunera YES
    SONY KV-G21M1 \ G21P1 \ G21S11, KV-T21M1 \ T21MF1 \ T21MN1 \ T21MN11
    Method of exit from the service: Press 2 times the button POWER. Recording method
    in memory: Log in to press service combination of buttons on the remote one (UP) 4 (DOWN) will choose
    adjustable parameters. Press the MUTE button to call the screen WRITE (green), press
    0 key to enter into memory.
    SONY KV-21T10R
    Set the TV into standby mode and press the button on the remote control in sequence ON SCREEN DISPLAY
    SONY KV-21C4B/D/E/K/R KV-21X4A/B/D/E/K/L/R/U CHASSIS BE-5 CPU SDA5255-A024. Remote RM-836.
    Number outbreaks LEDs Code Error Description
    2 30 Controller chip Junglene confirms the transfer of high
    level I2C bus
    3 31 Error flag controller chip Jungle
    4 32 No signal reversal in the horizontal
    5 40 Sound processor does not support the transmission of high-level
    I2C bus
    6 91 No vertical sync
    7 10 Nonvolatile memory NVMne confirms the transfer of low-
    level I2C bus
    8 20 The tuner does not confirm the transfer of high-level I2C bus
    9 01 Error general I2C Bus
    10 90 Input protection: protection of the X-ray (X-rays).
    SONY KV29F3A/B/D/E/K/R/U CHASSIC BE-3D Processor SDA302C263-GEG Remote RM-862
    Error
    Kontreller JUNGLE / CHROMA not responding 6
    MSP does not meet the 9
    NVM is not responsible 10
    SHARP 14 \ 21 JN1 CHASSIS SP-51
    When the input of the microcontroller 37 for 3 adjacent periods in a state
    High-level call service menu.
    SHARP VT-1428M, VT-2128M
    CH UP sequence for 2 seconds or more, and simultaneously press
    button POWER. Exit the menu button MENU.
    SHARP 54AT-15SC
    To enter the service, press the following buttons in sequence to the console. POWER OFF and then simultaneously
    VOL-and CH + on the TV. After that POWER ON and hold the VOL-and CH + until the TV will not start.
    SHARP 14D-SC, 14B-SC, 20B-SC, 14D-CM, 21D-CK1, CV-2132CK1 CHASSIS PAL-A.
    Set the switch S1008 to the position servistnogo regime.
    SHARP 14R-SC/M8/M10, 14R-W, CV-14RU
    Set the switch S1006 to the position servistnogo regime.
    SHARP DV-5450SC CHASSIS S3B Processor IX1492BM, SDA-20561
    To enter the service mode is necessary to block VIDEO
    connect terminals (2) and (6). Then press the MODE button on the remote.
    A message-SERV-. Then remove the jumper. The choice of adjustment of the CH and
    CH +.
    SHIVAKI CHASSIS 11AK19
    To enter the sersisny mode, do the following manipulation. First enter the installation menu
    INSTALL button and then press a key on the remote in the following sequence
    4, 7, 2 and 5. Look for the menu position ADJUST (all adjustments are changed through it).
    SHIVAKI STV1415 CHASSIS 11AK20
    To enter the service menu must be made within 4 seconds to perform the login procedure. Must
    press the remote control the following sequence of keys. (VOL-), (Prog), (-),
    (TV). Options selected buttons (PROGRAM UP) (PROGRAM DOWN), and the change (VOL-),
    (VOL +). To store, press the red button. To exit, use the button TV.
    SHIVAKI STV2905 CHASSIS DY-900
    1. Click on SERVICE remote.
    2. In this case, the image appears OSD (onscreen display) « Line SVC ». Then click on the button -/– control.
    3. At this time the load data recorded in the micro-channels of memory.
    4. The downloaded data are as follows:
    (1). STD
    4CH
    and
    62,25 Mg
    (2). STD
    5CH
    and
    172,25 Mg
    (3). STD
    7CH
    and
    189,25 Mg
    (4). STD
    25CH
    and
    503,25 Mg
    (5). STD
    34CH
    and
    575,25 Mg
    (6). STD
    40CH
    and
    623,25 Mg
    (7). STD
    50CH
    and
    703,25 Mg
    1. Color fixed channels OSD – Green.
    2. To view the channels recorded in the memory press PR +, -.
    Adjust V-SIZE (vertical size)
    1. To receive a test table RETMA press the PR +, -.
    2. To perform the adjustment, press « 6 » remote control, and the image appears OSD « STV VAMP32 ».
    3. Clicking on knokli VOL +, – to adjust the vertical size. The remaining adjustment onalogichny.
    SHIVAKI STV 2040 Chassis 11AK30-2 processor – ST92195C7B1/PAL VESTEL/T30F016, video processor – STV2248C
    Log-in service: Press MENU, then press the sequence 4 => 7 = 2 => 5
    SHIVAKI STV-2139 Processor – Z9023306PSC, video processor – TB1238BN
    Log-in service: in the operating mode to click in sequence on the remote control: DISPLAY => MUTE => SLEEP => FUZZY
    Mode selection menu: DISPLAY, SLEEP, MUTE
    THOMSON, TELEFUNKEN CHASSIS TX-90, TX-91
    Put TV into standby mode with remote control. Then turn off the mains button. Press the teletext button on the remote (blue)
    and holding to include a network switch. Then release the button Teletext dramatically and immediately click.
    THOMSON a new generation.
    With the power off press the side « V- » and « P- » deduct and include meals. Services menu appears.
    THOMSON 21MG77C
    THOMSON 21MG10E Processor: TDA9554PS/N1/0301
    To access the menu, do the following
    1. TV – in stand-by (standby mode) with the remote.
    2. Turn off the TV network button.
    3. Udepzhivaya teletext button on the remote, switch on the TV network button.
    4. After turning on the LEDs in full REGIME – what have you got – green, lupus?), Release the button Teletext
    5. If you do not spabotaet, all the same, only in part 4 teletext button again and release quickly to kpatkovpemenno press.
    TOSHIBA 1450 XN \ XNE 1458XNH 2050XN 2150 XNE \ XHC \ XC CHASSIS S5E
    Enabling self-control: When the screen displays the menu control, press
    the 9 button on your remote. Begin the process of self-testing.
    TOSHIBA 2150 (chassis – S5E)
    Login:
    1. mute
    2. again press the MUTE and otpyskat
    3. press the MENU button on the TV
    « 4 » – correction were kontpasta. « 1 », « 2 », « 3 » – cutoff R, G, B « AV » – Choice of test
    signal. « – gpomkost + » – pegylipovka.
    Output: off – power.
    TOSHIBA 2185XR
    1. Hazhat button on the remote control (MUTE)
    2. More paz press (MUTE) and do not let it go
    3. Hazhat on the TV button (Menu)
    Each press of a button (CHANNEL
    UP) changes the position pegulipovochnye Each press of a button (+ VOLUME) and (-VOLUME)
    change data. Exit – Turn off the TV.
    TOSHIBA
    1.B regime: SERVICE click on the button box – line of horizontal
    ON / OFF (kpuzhochek with stpelkoy). Each subsequent press changes kaptinku.
    2. In the regime of the menu pegulipovok book. (9) entry in the menu self
    SELF CHECK. ******** – Nome.p mikpoppotsessopa Power – 00 – diagnostics unit
    supply. 00 – nopma if the numerals of one another in many shows paz spabatyvala system
    protection – a tendency to current overload. Bus line – the verification of tire chains.
    OK-nopma, SDA – GND – goat SDA bus on the lot, SCL – GND – similar bus SCL.
    SDA-SCL – essno among themselves. Bus cont – the verification of tire components. OK – nopma.
    Q *** NY – mikposhema with nome.p *** neisppavna. SYNC – sinhponizatsiya. OK – nopma.
    NG – ppots. This function operates and attempts to define a type of video
    UNIMOR Model – SIESTA-3/3A Processor SDA20562-A508/A515/A522.
    Log into the service menu: Close the output 21 to ground. Click on the TV (P +) and (P) and include a network switch.
    WALTHAM Model – WT821
    Log into the service menu – the TV remote control « Horizon » without graphics click (SERVICE),
    indekatore displayed on CH, Press again – there will be PR on the volume selected number of registers (1-4)
    and numbers (1-9) to change bits. After the press (Memory).
    XANTRAX TC-2172S (chassis TD-18)
    Video Processor: TD1238N
    Control Processor: TMP87CK38N
    There are three service modes: S, D, M.
    S-Mode – the service;
    D-mode – extended service;
    M-mode – expedited + training.
    Log in to the service S-mode control (SERVICE MODE) with a conventional
    remote control: in the operating mode of the TV, press and hold
    on the front panel button VOL-(volume at minimum position), press the
    button on the remote DISPLAY. In the upper left corner of the screen
    TV will be the symbol S is the inclusion of a special regime of service
    regulation.
    Selection of a new function by pressing the button on the remote control or PROG + PROG-.
    Adjusting the value of the function by pressing the remote button VOL + or VOL-.
    When pressed on the remote control button on the screen disappears -/–
    Frame Scan. From the emission of a narrow horizontal band handle
    accelerating voltage.
    The values ​​of the controlled functions are stored in memory automatically.
    Log in to service mode D, M possible only with a special service remote control.
    TV returns to normal operation after turning off the network and then on again.
    XANTRAX TC-1466, TC-2066S, TC-2166S, TC-2068S, TC-2168S, Chassis ST-208, 209
    Video Processor: TDA8842
    Control Processor: MTV212MS64U
    Log in to the service adjustment mode (SERVICE MODE) with a conventional remote control:
    in standby mode, press the TV series on the remote control button, MUTE, AV, MENU, POWER.
    In the main user menu there is a new line – SERVICE.
    To enter a basic service menu, press the remote button VOL +.
    Reulirovka value of the function by pressing the remote button VOL + or VOL-.
    Selection of a new function by pressing the button on the remote control P + or P-.
    Schedule of Basic Tools:
    SCREEN – Reg. Screen settings
    CATHODE – Reg. Regimes cathodes
    TUNING – choice of parameters of the tuner
    SCR – subnasyschennost
    OSD Pos. – Adjusts the OSD position horizontally
    SCREEN, CATHODE, TUNING have their own sub-sub-menu.
    The values ​​of
    the controlled functions are stored in memory automatically. TV returns
    ZENITH IQB64W10W
    8-6-5-4-5-6-8
    7-5-3-2-3-5-7
    6-4-2-1-2-4-6
    7-5-3-2-3-5-7
    8-6-5-4-5-6-8
    Gain from control of the codes and press (ENTER) or (DISPLAY)
    ZENITH IQB64W10W
    9-8-7-6
    Gain from the control code and press (ENTER) or (DISPLAY)
